AVS VISU loses focus when switching screens
Is there a way to make the AVS Visu stay in focus when switching betweens with an embedded VISU?
Milk Drop works fine for this, and "locks in" when switching screens. The AVS however, goes behind RR, and you must then turn off the visu, and then turn it back on. Couldn't the routine that "Keeps the Milk Drop Visu from screen to screen", be applied to the code that handles the AVS Visu?
Also, the AVS Visu does not always lock correctly into the defined APP area. It's kind of hit and miss.
Here is the Visu on my main menu:
http://img220.imageshack.us/img220/6186/visual1vl1.jpg
Here it is on the audio screen where it is supposed to be:
http://img517.imageshack.us/img517/7531/visual2yo6.jpg
And here is what happens quite frequently when trying to embed it, it "remembers" the top bar location from the main menu, and does not embed where it is defined.
http://img459.imageshack.us/img459/8977/visual3iy2.jpg
You can see from the 2nd screen cap, that the area is properly defined for the visu to "lock to", but its hit and miss if it actually locks into the correct spot or not.
