Results 1 to 5 of 5
Thread: Screen resolution awry when set to "default"
    Maximum Bitrate crooper's Avatar
    Nov 2006
    Everett, WA
    When using the current RR Config program I find that if I don't manually set the screen resolution/refresh EVERY time I open the Config program, it sets RR to a "default" of 1920x1200x32 (or something like that) and my Xenarc can't handle it (unintelligible lines across the screen). This is especially problematic since I have RR in the startup folder so it'll start with Windows. It requires a Safe Mode boot to fix the problem.
    Anybody else get this?
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by crooper View Post
    Try setting resolution in general.ini file in your skin.
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    ie.
    Original to the original resolution of the skin / Show to the resolution you want it to be.
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    do you actually need RR to set the resolution for you ? cause you could look for the
    "resolution=" in RR.INI and remove it.. but it could be an issue with the config.. I haven't tested it, but it should not save the resolution= line to the INI if it's set as "default".
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I guess I'll speak up, that WAS an issue with the config that was issued with the last RR release, but if you go and get the latest config, it won't happen.
    @wizz
    FYI, those settings only apply to the skin part, his problem is the actuall reslolution that the screen is using.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2006
    Everett, WA
    Thanks Blue ZX3! I thought I had the latest version, apparently not.
  1. T3 screen resolution and Infill Station
    By irdrive in forum Infill T3
    Last Post: 05-08-2007, 12:42 PM
  2. need help to set up touch screen !!!!!
    By choier1983 in forum LCD/Display
    Last Post: 03-29-2007, 08:45 AM
  3. Replies: 5
    Last Post: 02-13-2006, 08:51 PM
  4. touch screen resolution problem
    By dugg35 in forum Newbie
    Last Post: 08-25-2005, 12:20 AM
  5. Screen resolution
    By futuresweets10 in forum General Hardware Discussion
    Last Post: 01-18-2005, 01:16 PM
