Results 1 to 8 of 8
Thread: 50% load after resume
    May 2006
    I drive about 20 miles a day; about 3 times a week I have one or more seemingly random events since the september updates (everything fine before then)
    1. Comes out of hibernate running 50% CPU load, very sluggish and if I invoke IG it locks up the machine (1.6G dual core 2)
    2. GPS time randomly resets date/time regardless of RR.INI being GPSUSADATE=TRUE or removed)
    3. Won't resume to playing music regardless of RESUMEMUSIC=2
    These things happen intermittently, and with HIBERNATEAWARE=True or removed, so it's hard to pin down, anything I can do to help let me know...
    Running XP SP2
    RR 9/30
    WInamp 5.2.4.703
    XPort 3
    IG 4
    Phoco 1.7 regged
    gammacontrol
    IGQWERTY
    medialaunch
    RR.INI
    voice=true
    musicpath=C:\Documents and Settings\Richard G. Pecoraro\My Documents\My Music\
    videopath=C:\Documents and Settings\Richard G. Pecoraro\My Documents\My Videos\
    dvdpath=Internal
    launchpath=C:\Program Files\Road Runner\Launch\
    winamppath=C:\Program Files\Winamp\
    skinpath=C:\Program Files\Road Runner\skins\Chameleon\
    nightskin=C:\Program Files\Road Runner\skins\Chameleon Night\
    mpcpath=C:\Program Files\Road Runner\mplayerc.exe
    screentype=16:9
    videoautohide=false
    videohidetime=2
    videofiles=.avi,.wmv,.mp4,.mpg,.mpeg,.lnk
    audiofiles=.lnk,.cda,.mp3,.wma,.m3u
    hidemouse=true
    albumart=*.txt
    useid3=2
    showid3playlist=true
    showid3browse=true
    gpsmode=2
    gpsport=8
    mapmonkeypath=Click here to set path
    gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
    gpsname=iGuidance
    exitmode=0
    showicons=true
    showextensions=false
    titlesafter=
    listfollowssong=true
    resumemusic=2
    audiorepeat=off
    audioshuffle=off
    gammamode=1
    gammapath=C:\Program Files\Road Runner\Gamma\GammaControl.exe
    dateformat=Short Date
    timeformat=HH:MM AM/PM
    id3listformat=%title%
    id3browseformat=%title%
    mastervolmap=0
    listnumbers=false
    noformat=false
    hidewinamp=true
    visuname=!Winamp Gen!AVS
    overspeed=55
    scrollmode=1
    builtinvideo=false
    disableinternat=true
    locale=0
    hidetaskbar=true
    hidedesktop=true
    radiomode=0
    radioline=0
    playlistpath=C:\Program Files\Winamp\Playlists\
    lazytag=false
    allowallfreqs=false
    browsertype=1
    browserpath=C:\Program Files\Internet Explorer\iexplore.exe
    mapvol=50
    isunits=false
    phocopath=C:\Program Files\PhoneControl.NET\PhoneCtl.NET.exe
    phoconodesign=true
    btdevicename=3100/3125
    phonelistspath=C:\Program Files\PhoneControl.NET\PhoneBooks\
    contactspicturespath=C:\Program Files\PhoneControl.NET\Photos\
    ringtone=C:\Program Files\PhoneControl.NET\Sounds\SMS.wav
    smstone=C:\Program Files\PhoneControl.NET\Sounds\SMS.wav
    standardphonebook=0
    maxcalllistentries=100
    debugmode=true
    hibernateaware=true
    enableclipping=true
    soundcard=0
    screenlimit=7
    nozoom=0
    ipoddrive=Click here to set drive
    resolution=800x600x32x60
    usegestures=false
    leavemousealone=false
    hibernatereload=false
    forcehibernate=true
    closeapps=false
    cityweather=Bellevue, NE
    weatherunits=USA
    picspath=C:\Documents and Settings\Richard G. Pecoraro\My Documents\My Pictures\
    transition=3
    fadeimages=true
    preload=Audio_Player.skin
    preload=audio_browser.skin
    preload=EXTERNAL_GPS.skin
    preload=menu2.skin
    preload=windvd_player.skin
    preload=picviewer.skin
    HIDEDOTS=TRUE
    ignative=false
    gpstime=true
    lastscreenswitchtime=10
    pauseonvoice=true
    gpsonvoice=true
    useDualMon=true
    gasfinderautorefresh=true
    igautosw=true
    fastmode=-1
    fadeinvolume=true
    pathlimit=true
    TransitionTime=0.3
    localdatacaptureinterval=10
    startcommand=MEDIALAUNCH
    EXECTBL.INI
    /, This (OPTIONAL) file contains translation commands.
    /, RR will accept the commands defined on the LEFT
    /, and execute them as expressed on the RIGHT
    /, you can use this to create or redefine any command
    /, (or to add functionality to any syandard command).
    /, The Format of this file is (by choice):
    /, "<COMMAND>","<EXEC COMMAND>"
    /, "<COMMAND>","<EXEC COMMAND>",filename.skin
    /, Examples:
    /, "AUDIO","LOAD;audio_player.skin;Audio Player"
    /, "RESTARTSONG","SEEKTO;00:00",audio_player.skin
    /, Extas:
    /, XM, FM and MM can be used instead of a skin file
    /, to be translated when XM, FM or MM is turned ON.
    /, PLAY, PAUSE and STOP can be used instead of skin
    /, file name so it executes commands based on MP3 or
    /, Video playback status.
    /, Set Bellow the Path to the CDRip plugin (if used)
    "CDRIP","PLUGIN;RRCDRip;C:\VBStuff\Road Runner\CDRip\CDRip.exe"
    "QUIT","SendMsg;RRCDRip;showplugin||bye"
    "BYE","QUIT"
    /, You can add commands to execute before suspend
    /, and after resume, using the codes bellow:
    "ONSUSPEND",""
    "ONRESUME","PLAY||RUNQ;C:\Program Files\Road Runner\LAUNCH\2-Xport Restart\restartxport.bat||reloadskin"
    "ONLINE","gasrefresh||LoadAllWeather||LoadMaps||RE LOADWEATHER"
    "OFFLINE",""
    /, "ONFILECLICK",""
    "ONDIRCLICK","BROWSE",picviewer.skin
    "ONPLCLICK",""
    "ONDLCLICK",""
    "ONPBCLICK",""
    "ONPLSELCLICK",""
    "ONDLSELCLICK",""
    "ONSONGSTART",""
    "ONSKINSTART",""
    /, For MediaCar Compatibility only:
    "AUDIONEXT","RRNEXT"
    "AUDIOPREV","RRPREV"
    /, OSK Gestures (Changes not recommended)
    "GEST-A","A",osk.skin
    "GEST-B","B",osk.skin
    "GEST-C","C",osk.skin
    "GEST-D","D",osk.skin
    "GEST-E","E",osk.skin
    "GEST-F","F",osk.skin
    "GEST-G","G",osk.skin
    "GEST-H","H",osk.skin
    "GEST-I","I",osk.skin
    "GEST-J","J",osk.skin
    "GEST-K","K",osk.skin
    "GEST-L","L",osk.skin
    "GEST-M","M",osk.skin
    "GEST-N","N",osk.skin
    "GEST-O","O",osk.skin
    "GESTURE-P","P",osk.skin
    "GEST-Q","Q",osk.skin
    "GEST-R","R",osk.skin
    "GEST-S","S",osk.skin
    "GEST-T","T",osk.skin
    "GEST-U","U",osk.skin
    "GEST-V","V",osk.skin
    "GEST-W","W",osk.skin
    "GEST-X","X",osk.skin
    "GEST-Y","Y",osk.skin
    "GEST-Z","Z",osk.skin
    /, Global Gestures
    "GEST-M","AUDIO"
    "GEST-X","EXIT"
    "GEST-H","MAIN"
    "GEST-L","LOAD;AUDIO_BROWSER.SKIN"
    /, Car2PC Interface Support
    "HUSTART","RESUME"
    "HUSTOP","PAUSE"
    "NT ","RRNEXT"
    "PT ","RRPREV"
    "PA ","PLAY"
    "FF 1","STARTFFWD"
    "FF 0","STOPFFWD"
    "FR 1","STARTFRWD"
    "FR 0","STOPFRWD"
    "DS 001","AUDIO"
    "DS 002","VIDEO"
    "DS 003","RADIO"
    "DS 004","XM"
    "DS 005","GPS"
    "DS 006","DVD"
    "MX 1","SHUFFLE"
    "MX 0","SHUFFLE"
    "RP 1","REPEAT"
    "RP 0","REPEAT"
    /, My Additions
    "WEB","PLUGIN;WebPlugin;WebPlugin.exe"
    "GPS","LOAD;EXTERNAL_GPS.SKIN;G P S Navigation;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe "nowarning";iGuidance"
    "MENUGPS","RUN;C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe "nowarning";iGuidance"
    /, "GPS","LOAD;EXTERNAL_GPS.SKIN;G P S Navigation;C:\Program Files\Delorme\Street Atlas USA 2006\SA2006.exe;DeLorme Street Atlas USAŽ 2006"
    "IDLE","EXIT"
    "TIMER","BYVAR;SLIDESHOW;<<NEXTPIC"
    "RELOADRR","RUN;LSTOOLS\SCRIPTS\RESTARTRR.exe||QUI T"
    "GASNAV","GPS"
    "MEDIALAUNCH","Run;C:\Program Files\Road Runner\MediaLaunch\MediaLaunch.exe"
    "IGPAUSE","SETVOL;WINAMP;205"
    "IGRESUME","SETVOL;WINAMP;255"
    My skin's EXECTBL.INI
    /, My Additions
    "ONDIRCLICK","LOAD;audio_browser_2.skin||BROWSE",a udio_browser.skin
    "ONFILECLICK","SETVARBYCODE;LISTTEXT;LISTTEXT||LDI MG;295;106;445;332;$skinpath$Backgrounds\$LISTTEXT $;OUT||LOADIMG;295;106;445;332;Menu_Off.png;OUT",B uttoncolor.skin
    "ONFILECLICK","SETVARBYCODE;LISTTEXT;LISTTEXT||LDI MG;295;106;445;332;$skinpath$Logos\$LISTTEXT$;OUT| |LOADIMG;295;106;445;332;Menu_Off.png;OUT",Logos.s kin
    "LoadAllWeather","RUNW;$skinpath$Weather\WeatherDo wnloader.exe"
    "LoadMaps","RUNW;$skinpath$Weather\ConvertWeather. exe"
    "ConvertMaps","RUNQ;$SkinPath$Weather\gifswfsh.exe |*.* /g /c"
    SKIN.INI
    background=C:\Program Files\Road Runner\skins\Chameleon\Back.jpg
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can you check which process actually is loading up the CPU ?
    I would start by turning off gamma control and/or upgrading winamp to see..
    Ride Runner RR's Myspace
    May 2006
    Quote Originally Posted by guino View Post
    It's ROADRUNNER.EXE itself (as shown by task manager) Will try those two ideas next, thanks
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Does it stay at 50% load until you close it or does it ever stabilize to normal after awhile ? and if so, how long till that happens?
    May 2006
    It stays at 50% for approx 3 minutes if I leave it alone and wait, then the computer reboots
    guino's Avatar
    Nov 2004
    Toronto, Canada
    can you make a debug log ? (Add: debugmode=true to RR.INI then run it, suspend/resume and close RR, then ZIP the file debug.txt it creates in RR's folder and post it here)
    May 2006
    Yes, might take a day or a few since it's kind of sporadic
    May 2006
    Luck, I went to turn debug on and it WAS on...I don't remember why...anyway you can see where it's intermittently changing dates also, sometimes it appears to not execute the onresume, and there's alot of data...i have no idea what to look for...good luck
    Attached Files Attached Files
  1. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 08:58 PM
  2. Hibernate resume + load = restart
    By crooper in forum Power Supplies
    Last Post: 02-21-2007, 02:07 AM
  3. FS: M10000, Morex 3688, 40GB 2.5", SLOT Load dvd/cdrw, 512mb ram
    By JuMpMaN6235 in forum Classified Archive
    Last Post: 07-13-2006, 10:53 AM
  4. Resume after hibernate scrutinized
    By ldave in forum PowerVoice
    Last Post: 02-09-2006, 11:04 PM
  5. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 06:57 PM
