Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: RoadRunner 09/09/07 -- Line-In/Winamp volume resets to 0% on resume
  1. #11
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by jizzajam View Post
    any ideas about this? i'm having the same issue: winamp and line-in volume set to 0 when resuming from hibernate. I don't think it happens everytime, i'm trying to figure out if hibernating in a particular state causes this (playing mp3s vs sat radio, etc)
    I think this is (as guino said) a Winamp issue. And I cant figure it out. I just uninstalled RR, and uninstalled Winamp. Then put on winamp 2.95 and RR version 11/04/06 and same deal. So I think it has something to do with that winamp dll being registered or something. That is the only variable that has changed. If I figure it out I will post.
    Also that crazy GPS thing happened again. Question for guino: If the name of the window for GPS does not match the actual name of the window, will it constantly open new versions of the GPS each time? I think what happened was I standby/resumed a few times in the GPS screen, so it spawned like 15 instances, and then when I pressed close, it would just seem like a new opened up, but it could be that it just showed me #14 of #15 because after I clicked close all the time, it worked fine. I am still investigating this...
    1.9in x 2.9in -- 47mm x 73mm
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Maybe you guys want to try usbsound=true in RR.INI -- this forces RR to wait for the mixer to become available after resuming (normally only USB sound cards "disconnect" on hibernate/standby). I do recommend testing winamp on its own to see how it works, and it should be similar in RR, and if it isn't, hibernateaware=false should make it EXACTLY as it is when outside RR.
    If the GPS title doesn't allow RR to find the GPS already opened, it will open a new process. A partial match should be enough to find it, but not if it's miss-spelled.. just make sure you check the window title in winspectorspy cause sometimes what you see in the window frame is not the actual title for it.
    Ride Runner RR's Myspace
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  2. Tutorial for installing pycar on Linux
    By kbyrd in forum PyCar
    Last Post: 11-01-2006, 01:59 PM
  3. Speaker Popping Noise (delay circuit options?), Line Drivers to boost volume which 1?
    By SuprchargdMazda in forum General Hardware Discussion
    Last Post: 05-26-2006, 08:57 PM
  4. Replies: 0
    Last Post: 11-27-2004, 06:47 PM
  5. Replies: 0
    Last Post: 11-04-2004, 06:46 PM
