Results 1 to 8 of 8
Thread: New iList Bug/bmp mode
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    With the newest RR 11/02/07, I have a strange problem now. When I select the unsel.bmp, sel.bmp the list is totally empty. I can click in it and it changes the playing song. If I select the transparent.bmp the list shows up with the fonts jagged, whereas in the browser skin the list behaves as it should. See the attatched screen shots.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, I forgot to mention this thing.. in order for Transparent iLists to work, I have to disable the "standard" anti-aliasing of fonts normally used in Windows -- meaning: most fonts will loose some quality, but hopefully, not too much (will greatly vary with the font used).
    The issue with your first iList I think is because you're trying to use the same BMP for two parameters (endbmp = unsel.bmp as well) -- this may be breaking the initialization of the iList since the file is already in use for the unsel BMP. You can probably just copy the file to some other name to prevent the issue.
    Ride Runner RR's Myspace
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Well, I tryed that too with a seperat end.bmp file. No matter what I do in the Audio_Player.skin, the iList is just not showing anything.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll test it right now (waiting on the airport anyway) -- You should not use the SD definition in the Audio player, unless you use a folder list in there as well.. in any case, place the IL definition BEFORE the S definition to try it out -- this is the "intended" way for it to work.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Got it Guino, I was missing a color definition in the my S definition.
    Thanks for your great work.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    was just about to say it worked as it should in my tests.. thanks for trying again :P
    Jul 2005
    Will there be any way for the initialising to be enabled with transparent ilists? The sharp jagged text is a pet hate for me. Lol
    guino's Avatar
    Nov 2004
    Toronto, Canada
    anti-aliasing with transparent ilists will not be possible simply because it makes the transparency stop working right -- and instead of showing jagged edges it shows darkish-pinkish dots all around the fonts.
  1. Quest for 800x480
    By ptk in forum LCD/Display
    Last Post: 01-04-2010, 11:42 AM
  2. Does XM mode operate as 'RADIO' mode
    By rjoek in forum Road Runner
    Last Post: 07-07-2005, 11:18 AM
  3. Police mode.!
    By Mcnovy in forum Road Runner
    Last Post: 05-17-2005, 04:13 PM
  4. BASIC Stamp question
    By Banderon in forum General Hardware Discussion
    Last Post: 05-07-2004, 09:33 AM
  5. More info on 800x480 mode for Xenarc...
    By InFix in forum LCD/Display
    Last Post: 08-27-2002, 09:54 AM
