Results 1 to 4 of 4
Thread: bug with playlist and line-in plugin
    Mar 2004
    Stockholm, Sweden
    I found a problem with the latest releases of Roadrunner, if you use the Line-in plugin for Radio...
    To recreate the problem:
    1:Set up Roadrunner to use the line in plugin for radio.
    2:Load a small playlist (like 15 songs or so).
    3:EXIT Roadrunner, and start it again
    4:Load a much larger playlist (more than 15 songs).
    5:Go to Radio, and then back to Audio.
    The playlist will be truncated to 15 songs (or whatever you had when you quit Roadrunner)
    Had this on 3 different installations, all uses Winamp 2.95 and all uses HCQT Radio. Tried with the latest version of Roadrunner 11-02-2007 with same result. Tried with different skins including BMV2, same...
    Can someone please verify that this is indeed a problem...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll check it.
    Ride Runner RR's Myspace
    Mar 2004
    Stockholm, Sweden
    OK, fixed it by adding a line to modRadio:
    'If Using Line In Pugin, load player with line in code
    If RUseLineIn Then
    [HL] Player.SavePlaylist Player_Path + "winamp.m3u"[/HL]
    Player.StopTrack
    Player.ClearPlaylist
    Player.AddItem RLineinPar
    Player.Play
    End If
    Probably have to do that in modSirius as well
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Thanks.. this sounds about right.
  1. Simplistique Skin Release - download and screenshots
    By lloydy in forum RR Released Skins
    Last Post: 05-04-2013, 11:58 AM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  3. Replies: 34
    Last Post: 11-06-2007, 03:42 PM
  4. Little issue i've been having with my playlist format
    By Sonicxtacy02 in forum Road Runner
    Last Post: 10-10-2007, 01:46 PM
  5. Playlist Saving Help please...
    By JohnWPB in forum Road Runner
    Last Post: 07-29-2007, 06:49 AM
