Results 1 to 10 of 14
Thread: Internet Explorer wont close
    Dublin
    Ok , this is a new one i haven't seen a bug for anywhere so ill post and see if anyone has come across this before.
    Pretty much everything on RR is now working for me since i went back to XP from vista (i refuse to use a capital for that) except one problem i have discovered.
    When i open an internet page all works ok , until i go back to the main RR screen and IE stays open and on top. I can move it and it moves fine and i can Alt+f4 and it closes, which is ok for me , but for anyone else using the system it seems a bit complicated.
    Has anyone seen where IE wont close before ?
    Thanks in advance and a great job with RR everyone
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can set the button code to exit the screen to "CLOSE" and it should close it, otherwise, you can make it "CLOSEWINDOW;Microsoft Internet Explorer||EXIT" and it should also close it before exiting. There's also a web plugin which works a little better than IE by itself.
    Ride Runner RR's Myspace
    Dublin
    Thanks Giuno ,
    I am using the plugin for it - in fact im using the default skin BVM2 (i think its called) with the link to WEB on it (though moved to a different location) and it opens with the IE embedded - its when i go back to the main RR window from that after clicking the top right hand button that i still see IE on top of the RR application - i think its supposed to keep the IE open , but RR is supposed to come to the front if im working this out correctly , but IE stays on top.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ummm.. You need to make sure you're not mixing the "WEB" command with the WEB "PLUGIN" command.. one has a built-in support to load IE outside RR and embed it, the other opens the web page inside the plugin (without running IE) -- Check the command used in the web button to see what you're actually running.
    Dublin
    B04,11,186,296,106,"web",""
    guino's Avatar
    Nov 2004
    Toronto, Canada
    See, this is NOT the web plugin -- it's the built-in browser support for using IE outside RR but embedded in the skin. The actual web plugin is available on my site for download and it is called using the PLUGIN command.
    Dublin
    Brilliant - ill check it out - thanks a million.
    Ill let you know how i get on - That RR program has myself and my friends in awe at how good and flexible it is.
    (any hints as to where to find this plugin? Cant seem to see it on the site)
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    You can download it form here
    http://www.kompassist.co.uk/
    Dublin
    Quote Originally Posted by guino View Post
    Brilliant - got it working and all is well with the world again. Thanks a million once again for all the help.
    Is there a way to set a default page on that plugin ?
    I figued out the bookmarks , but not the default page on it.
    Dublin
    Quote Originally Posted by peijffertje View Post
    Thanks for the link - made life easier.
  1. Replies: 0
    Last Post: 02-15-2007, 11:12 AM
  2. Set RR to close a program ... not hide
    By drPheta in forum Road Runner
    Last Post: 08-23-2006, 11:19 PM
  3. Cable TV over the internet
    By DrBuzzo in forum Wireless Communications
    Last Post: 12-06-2004, 05:57 PM
  4. internet explorer sucks
    By mp3z24 in forum Off Topic
    Last Post: 03-21-2002, 09:11 AM
