This is a variable available only from FLASH -- fscommands("GETPLPATHS"); and it will set _root.PLPATHS in the flash object with the paths of all files in the playlist. If you need the paths of the playlist from RR to use in a script or application, you should send a command to save the playlist from RR and read the file directly. If it's not working from Flash, do let me know... or tell me what you're trying to do and I'll try to help on it.
LinkBack URL
About LinkBacks
