Results 1 to 6 of 6
Thread: flash anims restarting on first load of a screen
    Low Bitrate fabi1's Avatar
    Nov 2007
    joyeuse, france
    Hello everyone,
    I'm using 2 flash movies that are common to all screens with same size and position of everything in all screens.
    There is an intro for both of them. When I load a screen that was never loaded before, it will restart the flash anims, but when the screen has already been loaded before, it is working fine.
    I could load the same anim without the intro on secondary screens, but isn't there a way to have it working directly?
    Anyone?
    thanks.
    Flash skin progress: ...50%
    Car restoring progress: ... As seen on picture ;)
    My music:
    http://www.jamendo.com/en/album/6933/
    My job:
    http://www.fa-b.net
    Nov 2007
    joyeuse, france
    Hello guino,
    I was thinking, is there a screen where I can poll all variables (CUSTOMDL is only viable on audiobrowser skin right?). The final Idea would be to stay in the same screen in a full flash app (no frames) and call all variables from it. So I would have to use audiobrowser as home screen.
    But... It would mean that cropping should be dynamic (is it?) and change size and pos with requests.
    I understand Road runner was not initially made to work with flash so this could change a little the way it would have to be coded. I don't know.
    What do you think? Is it possible with the current road runner version?
    My music:
    My job:
    http://www.fa-b.net
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can read CustomPL/DL/PB/CL from any screen.. however some functionality is only available on specific screens (so the settings you make in RRConfig are used). You can make a single menu.skin with a PL and DL and define the path used on the DL using the SD definition. This should allow you to use CustomPL/DL from there.
    There's no logic way to load a flash script while skipping its own intro/initial loading.
    Ride Runner RR's Myspace
    Nov 2007
    joyeuse, france
    aND WOULD YOU SAY DYNAMIC CROPPING OF RR COULD BE POSSIBLE?
    My music:
    My job:
    http://www.fa-b.net
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Dynamic cropping is not currently possible. If implemented, the problem would be restoring cropped areas. You're better off making menu screens with the desired areas cropped and in the position desired, then just load the menus you want at the desired times.
    Nov 2007
    joyeuse, france
    Yeah, I'm complicating things. I'll just have to load a new screen when I need to crop the window.
    My music:
    My job:
    http://www.fa-b.net
  1. 05 RX-8 custom fab install (motorized flip-up screen)
    By zenfe in forum Show off your project
    Last Post: 05-08-2009, 08:26 AM
  2. Replies: 33
    Last Post: 03-28-2008, 02:18 PM
  3. TO ALL SKINNERS (read this)
    By jeep642 in forum RR Skins
    Last Post: 06-23-2007, 05:45 PM
  4. Non-VGA screen to VGA
    By xxMIKExx in forum LCD/Display
    Last Post: 04-10-2007, 09:18 PM
  5. Lilliput touch screen Help..please
    By avn128 in forum LCD/Display
    Last Post: 08-03-2006, 04:20 PM
