Results 1 to 3 of 3
Thread: Milkdrop and the infamous SCROLLLOCK key...
    TMF
    TMF is offline
    Constant Bitrate TMF's Avatar
    Apr 2006
    Waterloo, IA -- cvmusclecars.com
    I knew that the last 30 years of programming hadn't gone to waste!
    Guino,
    I once reported a problem with handling the SCROLLLOCK key and passing it to Milkdrop. I think I even *bumped* the thread here earlier today. Anyway, I broke down and wrote a windows program to test some theories and figured out what the problem was, and more importantly, the solution which I will share!
    The problem: Milkdrop uses the ScrollLock key to lock/unlock the current visualization on the screen. This isn't a problem if you are only running WinAmp and have a Milkdrop window open and it has focus. But when you embed it in anything and try to pass the keystroke to it, it fails the second time you try again.
    In looking at the source to Milkdrop I learned a couple things.
    1. that trying to use a PostMessage with a single character is handled normally:
    Code:
       PostMessage(WinHandle, WM_CHAR, Ord('H'), 0);// Send a 'H' to the application handle
    2. That you need to send a SCROLLLOCK keypress differently:
    Code:
      PostMessage(WinHandle, WM_KEYDOWN, VK_SCROLL,0);  // and tell Milkdrop about it...
    3. That when Milkdrop received the WM_KEYDOWN message and processes it, it is told to go LOOK at the keyboard status light for ScrollLock and use whatever value it finds.
    4. When Milkdrom reads the keyboard status from Windows, it finds that it has not changed! So #2 above failed in spectacular fashion.
    THE SOLUTION!
    To tell Milkdrop to read the ScrollLock keyboard status is not enough. You first have to tell Windows to change the bits and either turn on or turn off the status light.
    So #2 needs to look like this:
    Code:
      SetLedState(ktScrollLock, ScrollLockState);  // Set ScrollLock to next saved state
      ScrollLockState := not ScrollLockState; // flip the state for next time
    The key is the first line. And here is the procedure I used to do this:
    Code:
    type
      TKeyType = (ktCapsLock, ktNumLock, ktScrollLock);
    procedure SetLedState(KeyCode: TKeyType; bOn: Boolean);
    var
      KBState: TKeyboardState;
      bCode: Byte;
    begin
      case KeyCode of
        ktScrollLock: bCode := VK_SCROLL;
        ktCapsLock: bCode := VK_CAPITAL;
        ktNumLock: bCode := VK_NUMLOCK;
      end;
      GetKeyboardState(KBState);
      if (Win32Platform = VER_PLATFORM_WIN32_NT) then
        begin
        if Boolean(KBState[bCode]) <> bOn then
          begin
            keybd_event(bCode,MapVirtualKey(bCode, 0),KEYEVENTF_EXTENDEDKEY,0);
            keybd_event(bCode,MapVirtualKey(bCode, 0),KEYEVENTF_EXTENDEDKEY or KEYEVENTF_KEYUP,0);
          end;
        end
      else
        begin
          KBState[bCode] := Ord(bOn);
          SetKeyboardState(KBState);
        end;
      end;
    This was written in Codegear/Borland Delphi 2007 but should be convertable to any other language. You do have to get the handle to the Milkdrop window to be able to tell it to change. I used this call to find it:
    Code:
       WinHandle := FindWIndow(nil, "milkdrop" );
    Anyway, I turned this into a small program that sits in the tasktray and call it in a skin with:
    Code:
    B08,2,6,81,63,"ACTIVATE;MilkDropHelper||SENDKEY;{S}" ,"ScrollLock"
    Hope this helps RoadRunner in that when you change the SENDKEY;{SCROLLLOCK} that you also flip the keyboard bits at the same time. Then I wouldn't need my helper app.
    Cheers!
    John
    No use steering now!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The sendkey command is actually provided by VB6.. RR uses keyb_event internally for a few things that are tricky like that. This however is a very specific/limited issue, I would rather see your helper app ziped/posted here (for anyone who desires to use the same feature), than make it built in.
    Ride Runner RR's Myspace
    TMF
    TMF is offline
    Apr 2006
    Quote Originally Posted by guino View Post
    I agree, but I've been experiencing a lockup in either Milkdrop or WinAmp when I try to send the keystrokes myself. I've downloaded the source to Milkdrop and have been poking through it to see where I might make the changes to have it use a kep other than ScrollLock. Now the trick is to get it to compile under CodeGear's RAD Studio 2007 (Borland C++ Builder 2007) and I'm working with them over on the WinAmp forum.
    I'll keep everyone posted as to what I find.
    Thanks!
    John
