Results 1 to 7 of 7
Thread: iList on menu.skin cause RR to crash with Run Time Error 438
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    If you put an ilist on the menu.skin, when RR loads it will crash with this error.
    Run Time Error 438 - Object Doesn't Support this Property or Method
    if you load RR without the ilist, it will load fine.
    Even if you copy over the menu.skin with one that has an ilist and "reloadskin" RR will still work fine. But if you exit RR and restart, it will crash again.
    It seems like the ilist is trying to initialize before RR has fully loaded the code that supports it.
    beer replenishment fund
    mp3car live search
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'll try it.. the load of the first screen is a little more picky then the load of secondary screens in RR.
    Ride Runner RR's Myspace
    Aug 2003
    Chicago
    not sure if this was fixed or not in the 12/6 update, people in my skin thread have reported success with it, but i am still getting errors if i have an ilist on the main menu and and also have an SD line. With the SD line i get error 13 type mismatch.
    mp3car live search
    guino's Avatar
    Nov 2004
    Toronto, Canada
    it was supposed to be fixed on 12/6 -- that's where you get the error 13 ? you may want to post your menu.skin so I can try it.
    Aug 2003
    Chicago
    its somewhat fixed in the fact you can run it with an ilist on the main menu, but if you also have an SD line on this same screen you get the error 13 type mismatch. i have removed the SD lines from the main menu as they really wernt needed, the code was just copied and pasted from another screen i had with ilist working. So for the most part its fine and there really isnt any reason to have an SD line on the main menu at least until formatting support for ilist is enabled.
    also, i was thinking cuz there are a lot of people who are still unable to run a skin that has ilist enabled for various reasons. There needs to be some kind of additional error checking or a better way to handle the initdx automation error. If RR detects that there are any problems with running DX it should automatically disable the ilist support and fall back to standard lists, gracefully instead of hanging. Also if there was an option in rr.ini to turn ilist support on/off
    useDX=True/False
    would make life easier for those who have a skin with ilist enabled but are unable to run them and dont know how to properly edit them or which .skins to edit to disable it.
    mp3car live search
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can you post the SD line you used ? and where it was (before/after the ilist) I swear I tested that as well.
    All good ideas btw.
    Jul 2006
    i was just thinkin the same thing about an option to disable ilists. would be useful for those who test on a VM or access their carpc via one.
  1. Needed: BETA Testers for Google Earth Plugin
    By guino in forum RR Released Plugins
    Last Post: 08-24-2012, 03:25 PM
  2. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 10:41 PM
  3. RR Crash when loading up video
    By DonkeyBoy in forum Road Runner
    Last Post: 09-29-2005, 11:42 AM
  4. RR 03-06-05 - Radio Preview ...
    By guino in forum Road Runner
    Last Post: 07-04-2005, 01:58 PM
  5. RR Crash: MM not found or not listening
    By wizz in forum RR Bug Tracker
    Last Post: 04-11-2005, 05:31 PM
