SKIPTO Not working correctly with Custom Lists
When you have a hidden value, and a displayed text field, the SKIPTO is working on the hidden Description, and not on the the viewable text.
The SKIPTO works fine, if you are just using one field to create the custom list, the problem happens when you use the "Text" AND the "Description Value".
For instance, you are viewing list of MP3 folders in your root MP3 directory. All of the paths begin with the drive letter, H in my case (H:\MP3). When I try the SKIPTO "L" for instance, the list does not move. However if I press "H" (My drive path) it will go to the top of the custom list. As it should, as "H" is the first letter for the command text in the custom list.
I hope this makes sense :) Its kind of hard to explain.
