Results 1 to 10 of 13
Thread: SKIPTO Not working correctly with Custom Lists
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    When you have a hidden value, and a displayed text field, the SKIPTO is working on the hidden Description, and not on the the viewable text.
    The SKIPTO works fine, if you are just using one field to create the custom list, the problem happens when you use the "Text" AND the "Description Value".
    For instance, you are viewing list of MP3 folders in your root MP3 directory. All of the paths begin with the drive letter, H in my case (H:\MP3). When I try the SKIPTO "L" for instance, the list does not move. However if I press "H" (My drive path) it will go to the top of the custom list. As it should, as "H" is the first letter for the command text in the custom list.
    I hope this makes sense Its kind of hard to explain.
    My Fiero Build Thread
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The issue here is that this command is only useful for "sorted" information. If you start placing things at random order in there, it won't work even if I make it work with the description.
    Ride Runner RR's Myspace
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yes, thats definitely understood The items in this list I am referring to, are in alphabetical order.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Maybe some flexibility of the skipto cmd. ie..."SKIPTO;k;TEXT" or "SKIPTO;k;DESC", so this would make the cmd syntax:
    SKIPTO;<letter>;<section of list to apply to>
    Just puttin my thoughts out on this...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    SKIPTO in Custom Lists
    So Guino, is this possible?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    will see what i can do..
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Thanks once again....
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Hey guino, I KNOW that you are a VERY busy man, just checking if you had a chance to look into this at all...
    No rush by any means..
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Aug 2004
    Germany
    If you're already looking at the code for this command : Could you also add SKIPTOPREV and SKIPTONEXT ?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This can be done currently with use of using RR code..
    Here is what you want, with full roll around scrolling supported ...
    Add this to your rr.ini file
    LTRNUM=0
    In your skin folder's Exectbl.ini file or RR's folder Exectbl.ini file add the following...
    Code:
    "SKIPTOPREV","EVAL;LTRNUM;$LTRNUM$-1||MYSKIPTO"
    "SKIPTONEXT","EVAL;LTRNUM;$LTRNUM$+1||MYSKIPTO"
    "MYSKIPTO","BYVAR;LTRNUM;MYSKIPTOSTART<<SKIPTO;A<<SKIPTO;B<<SKIPTO;C<<SKIPTO;D<<SKIPTO;E<<SKIPTO;F<<SKIPTO;G<<SKIPTO;H<<SKIPTO;I<<SKIPTO;J<<SKIPTO;K<<SKIPTO;L<<SKIPTO;M<<SKIPTO;N<<SKIPTO;O<<SKIPTO;P<<SKIPTO;Q<<SKIPTO;R<<SKIPTO;S<<SKIPTO;T<<SKIPTO;U<<SKIPTO;V<<SKIPTO;W<<SKIPTO;X<<SKIPTO;Y<<SKIPTO;Z<<MYSKIPTOEND"
    "MYSKIPTOEND","SETVAR;LTRNUM;1||GOTOFIRST||MYSKIPTO"
    "MYSKIPTOSTART","SETVAR;LTRNUM;26||GOTOLAST||MYSKIPTO"
    Now just use your "SKIPTONEXT" or "SKIPTOPREV" cmds like stated above
    And as always...ENJOY!!
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Bluetooth Dongle Not Working correctly
    By KingsDude in forum Wireless Communications
    Last Post: 05-17-2007, 02:30 PM
  2. m1-atx is this working correctly?
    By llajumpvid in forum Newbie
    Last Post: 05-28-2005, 12:12 PM
  3. cant change skins???
    By Hell-Stopper in forum FrodoPlayer
    Last Post: 11-05-2004, 11:10 PM
  4. BU-303 not working correctly
    By Mik in forum GPS
    Last Post: 08-21-2004, 05:28 PM
  5. Everything working correctly?
    By bgoodman in forum Off Topic
    Last Post: 09-15-2002, 01:13 AM
