Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
Thread: Touchscreen problems in RR at resume from Hibernate
  1. #11
    Constant Bitrate jac1502's Avatar
    Jan 2006
    I am still having this issue and this is my third system and second screen (although stil a lilliput just daylight readable).
    My issue occurs after standby. I have tried using Xport to restart the touchscreen drivers but then even the right click mouse button icon on the lower wont work or even my USB keyboard mouse button and I have to hit the windows key on my keyboard after ever button pushed until restart. I have also tried several different drivers with no luck. This is my last issue with my system as well and it only happens inside RR.
    Please Help!
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by jac1502 View Post
    Please Help!
    Your touchscreen doesn't work after resuming from standby ? or does it work any at all ? I'm not sure I understand the deal with the windows key button pushed until restart.
    If you HIBERNATE instead of Standby, does it work ?
    What is your hibernate aware setting in RR ?
    Ride Runner RR's Myspace
  3. #13
    Jan 2006
    Touchscreen functions fine on fresh boot or hibernate.
    Only issue occurs when I resume from standby
    Screen is plugged directly into PC no hub
    When I use Xport, which I thought restarts USB devices after standby, neither the screen nor my USB keyboard mouse buttons work. I can however press the windows key and bring up the windows menu on top of RR and get the screen and keyboard / mouse to function for one selection then it rarely works again until I hit the windows key again.
    When I do not restart any USB devices with Xport I can click the small mouse icon that is installed with most drivers and it will allow me to activate right click and use RR like normal until I move to a different screen
    RR is set to be aware of hibernate
    Thanks for any help, i have bulit a really nice system and on fresh boot it works fine but its so nice to have the speed of standby
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Can u make a debug log of you going in and out of standby ? this could help a lot looking for the issue.. hibernate and standby should be virtually the same...
  5. #15
    Jan 2006
    Here is the log file. I was not using Xport so the touchscreen mouse icon would allow me to toggle between left and right click to get RR to function until i changed screens then i had to toggle it again.
    2009 9:56:42 AM: Start -- Version: 7/1/2009
    8/12/2009 9:56:42 AM: OS Type: Windows XP
    8/12/2009 9:56:42 AM: FileManager: FileMode = Legacy
    8/12/2009 9:56:42 AM: FileManager: mypath = C:\Program Files\Road Runner\
    8/12/2009 9:56:42 AM: FileManager: ProfilePath = C:\Documents and Settings\Benz\My Documents\RideRunner\
    8/12/2009 9:56:43 AM: Master Vol: Volume Control/4
    8/12/2009 9:56:43 AM: GetLineControl Failed: 401
    8/12/2009 9:56:43 AM: No Treble Support
    8/12/2009 9:56:43 AM: No Bass Support
    8/12/2009 9:56:43 AM: No Master ON/OFF
    8/12/2009 9:56:43 AM: Source: Wave=&H1008/1
    8/12/2009 9:56:43 AM: Source: SW Synth=&H1004/2
    8/12/2009 9:56:43 AM: Source: CD Player=&H1005/3
    8/12/2009 9:56:43 AM: Source: Microphone=&H1003/4
    8/12/2009 9:56:43 AM: Source: Aux=&H100A/5
    8/12/2009 9:56:43 AM: Source: Line In=&H1002/6
    8/12/2009 9:56:43 AM: Source: Wave=&H1008/7
    8/12/2009 9:56:43 AM: Can't Open Source
    8/12/2009 9:56:43 AM: No Mute for Source
    8/12/2009 9:56:44 AM: PLAYER: Winamp Version: 2.05
    8/12/2009 9:56:44 AM: DirectDraw Count: 1 - []
    8/12/2009 9:56:44 AM: No Phidgets interface detected.
    8/12/2009 9:56:44 AM: Plugin Manager: loading Global Plugins...
    8/12/2009 9:56:44 AM: Plugin Manager: Plugin Found: MovieTimes
    8/12/2009 9:56:44 AM: Plugin Manager: Warning Plugin MovieTimes does not support Enabled Method
    8/12/2009 9:56:44 AM: Plugin Manager: Warning Plugin MovieTimes does not support Initialize Method
    8/12/2009 9:56:44 AM: Plugin Manager: Plugin loaded (Global): MovieTimes
    8/12/2009 9:56:44 AM: Plugin Manager: Plugin Found: SkinTool
    8/12/2009 9:56:44 AM: Plugin Manager: Warning Plugin SkinTool does not support Enabled Method
    8/12/2009 9:56:44 AM: Plugin Manager: Plugin loaded (Global): SkinTool
    8/12/2009 9:56:44 AM: Plugin Manager: loading Global Plugins Completed.
    8/12/2009 9:56:44 AM: LoadSkin: C:\Program Files\Road Runner\Skins\BMV2old\
    8/12/2009 9:56:44 AM: Plugin Manager: loading SkinDir Plugins...
    8/12/2009 9:56:44 AM: Plugin Manager: loading SkinDir Plugins Completed.
    8/12/2009 9:56:46 AM: CheckResume: ResumeMusic=1 WasRadio=0
    8/12/2009 9:56:46 AM: Enter Exec: False, menu.skin, , False
    8/12/2009 9:56:46 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
    8/12/2009 9:56:46 AM: Leave Exec: False, menu.skin, ONSKINSTART, False
    8/12/2009 9:56:46 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
    8/12/2009 9:56:46 AM: Leave Exec: False, menu.skin, ONSONGSTART, False
    8/12/2009 9:56:49 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 9:56:49 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 9:56:49 AM: Que Exec: True, menu.skin, "AUDIO", False
    8/12/2009 9:56:49 AM: Executing: AUDIO
    8/12/2009 9:56:49 AM: Enter Exec: True, audio_player.skin, , False
    8/12/2009 9:56:49 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    8/12/2009 9:56:49 AM: Que Exec: True, audio_player.skin, "ONSOURCECHANGE", False
    8/12/2009 9:56:49 AM: Leave Exec: False, audio_player.skin, ONSOURCECHANGE, False
    8/12/2009 9:56:52 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:52 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:52 AM: Que Exec: True, audio_player.skin, "VOL+", False
    8/12/2009 9:56:52 AM: Executing: VOL+
    8/12/2009 9:56:52 AM: Leave Exec: False, audio_player.skin, VOL+, False
    8/12/2009 9:56:52 AM: Enter Exec: False, audio_player.skin, "VOL+", False
    8/12/2009 9:56:53 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    8/12/2009 9:56:53 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    8/12/2009 9:56:53 AM: Que Exec: True, audio_player.skin, "PLAY", False
    8/12/2009 9:56:53 AM: Executing: PLAY
    8/12/2009 9:56:54 AM: Leave Exec: False, audio_player.skin, play, False
    8/12/2009 9:56:56 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:56 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:56 AM: Que Exec: True, audio_player.skin, "VOL+", False
    8/12/2009 9:56:56 AM: Executing: VOL+
    8/12/2009 9:56:56 AM: Leave Exec: False, audio_player.skin, VOL+, False
    8/12/2009 9:56:57 AM: Enter Exec: False, audio_player.skin, "VOL+", False
    8/12/2009 9:56:57 AM: Que Exec: True, audio_player.skin, "VOL+", False
    8/12/2009 9:56:57 AM: Executing: VOL+
    8/12/2009 9:56:57 AM: Leave Exec: False, audio_player.skin, VOL+, False
    8/12/2009 9:56:57 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:57 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:58 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:58 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 9:56:58 AM: Que Exec: True, audio_player.skin, "VOL+", False
    8/12/2009 9:56:58 AM: Executing: VOL+
    8/12/2009 9:56:58 AM: Leave Exec: False, audio_player.skin, VOL+, False
    8/12/2009 9:56:58 AM: Enter Exec: False, audio_player.skin, "VOL+", False
    8/12/2009 9:56:59 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 9:56:59 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 9:56:59 AM: Que Exec: True, audio_player.skin, "VOL-", False
    8/12/2009 9:56:59 AM: Executing: VOL-
    8/12/2009 9:56:59 AM: Leave Exec: False, audio_player.skin, VOL-, False
    8/12/2009 9:57:03 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 9:57:03 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 9:57:03 AM: Que Exec: True, audio_player.skin, "VOL-", False
    8/12/2009 9:57:03 AM: Executing: VOL-
    8/12/2009 9:57:03 AM: Leave Exec: False, audio_player.skin, VOL-, False
    8/12/2009 9:57:10 AM: WM_POWERBROADCAST: wParam=0
    8/12/2009 9:57:10 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    8/12/2009 9:57:10 AM: PrepareForHibernate: (Start)
    8/12/2009 9:57:10 AM: Enter Exec: False, audio_player.skin, "ONSUSPEND", False
    8/12/2009 9:57:10 AM: Que Exec: True, audio_player.skin, "ONSUSPEND", False
    8/12/2009 9:57:10 AM: Leave Exec: False, audio_player.skin, ONSUSPEND, False
    8/12/2009 9:57:10 AM: PrepareForHibernate: (After radio power's)
    8/12/2009 9:57:10 AM: PrepareForHibernate: Event/File Flush (end sub)
    8/12/2009 9:57:13 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    8/12/2009 11:45:30 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
    8/12/2009 11:45:30 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    8/12/2009 11:45:30 AM: ---------------------------->
    8/12/2009 11:45:30 AM: ResumeFromHibernate: (start)
    8/12/2009 11:45:30 AM: ResumeFromHibernate: (Resuming = true)
    8/12/2009 11:45:32 AM: ResumeFromHibernate: (after resume delay)
    8/12/2009 11:45:32 AM: Enter Exec: False, audio_player.skin, "ONRESUME", False
    8/12/2009 11:45:32 AM: Que Exec: True, audio_player.skin, "ONRESUME", False
    8/12/2009 11:45:32 AM: Leave Exec: False, audio_player.skin, ONRESUME, False
    8/12/2009 11:45:32 AM: ResumeFromHibernate: Start tuners... Sirius, XM, & HD
    8/12/2009 11:45:32 AM: CheckResume: ResumeMusic=1 WasRadio=0
    8/12/2009 11:45:33 AM: ResumeFromHibernate: (End Sub)
    8/12/2009 11:45:33 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    8/12/2009 11:45:33 AM: ResumeFromHibernate: (Hibernated = False)
    8/12/2009 11:45:44 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 11:45:44 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 11:45:44 AM: Que Exec: True, audio_player.skin, "VOL+", False
    8/12/2009 11:45:44 AM: Executing: VOL+
    8/12/2009 11:45:44 AM: Leave Exec: False, audio_player.skin, VOL+, False
    8/12/2009 11:45:46 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 11:45:46 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL+", False
    8/12/2009 11:45:46 AM: Que Exec: True, audio_player.skin, "VOL+", False
    8/12/2009 11:45:46 AM: Executing: VOL+
    8/12/2009 11:45:46 AM: Leave Exec: False, audio_player.skin, VOL+, False
    8/12/2009 11:45:50 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:45:50 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:45:50 AM: Que Exec: True, audio_player.skin, "EXIT", False
    8/12/2009 11:45:50 AM: Executing: EXIT
    8/12/2009 11:45:50 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:45:50 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    8/12/2009 11:45:55 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:45:55 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:45:55 AM: Que Exec: True, menu.skin, "AUDIO", False
    8/12/2009 11:45:55 AM: Executing: AUDIO
    8/12/2009 11:45:55 AM: Enter Exec: True, audio_player.skin, , False
    8/12/2009 11:45:55 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    8/12/2009 11:45:55 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    8/12/2009 11:46:12 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:46:12 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:46:12 AM: Que Exec: True, audio_player.skin, "EXIT", False
    8/12/2009 11:46:12 AM: Executing: EXIT
    8/12/2009 11:46:12 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:46:12 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    8/12/2009 11:46:16 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||VIDEO", False
    8/12/2009 11:46:16 AM: Que Exec: True, menu.skin, "ONBTNPRESS||VIDEO", False
    8/12/2009 11:46:16 AM: Que Exec: True, menu.skin, "VIDEO", False
    8/12/2009 11:46:16 AM: Executing: VIDEO
    8/12/2009 11:46:19 AM: Que Exec: True, video_player.skin, "ONSCREENCHANGE", False
    8/12/2009 11:46:19 AM: Que Exec: True, video_player.skin, "ONSOURCECHANGE", False
    8/12/2009 11:46:19 AM: Leave Exec: False, video_player.skin, ONSOURCECHANGE, False
    8/12/2009 11:46:19 AM: Enter Exec: False, video_player.skin, , False
    8/12/2009 11:46:19 AM: Que Exec: True, video_player.skin, "ONSONGSTART", False
    8/12/2009 11:46:19 AM: Leave Exec: False, video_player.skin, ONSONGSTART, False
    8/12/2009 11:46:32 AM: Enter Exec: False, video_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:46:32 AM: Que Exec: True, video_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:46:32 AM: Que Exec: True, video_player.skin, "EXIT", False
    8/12/2009 11:46:32 AM: Executing: EXIT
    8/12/2009 11:46:32 AM: Enter Exec: True, menu.skin, , False
    8/12/2009 11:46:32 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:46:32 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
    8/12/2009 11:46:32 AM: Leave Exec: False, menu.skin, ONSONGSTART, False
    8/12/2009 11:46:32 AM: Enter Exec: False, menu.skin, , False
    8/12/2009 11:46:54 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:46:54 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:46:54 AM: Que Exec: True, menu.skin, "AUDIO", False
    8/12/2009 11:46:54 AM: Executing: AUDIO
    8/12/2009 11:46:54 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    8/12/2009 11:46:54 AM: Que Exec: True, audio_player.skin, "ONSOURCECHANGE", False
    8/12/2009 11:46:54 AM: Leave Exec: False, audio_player.skin, ONSOURCECHANGE, False
    8/12/2009 11:47:01 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    8/12/2009 11:47:01 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    8/12/2009 11:47:01 AM: Que Exec: True, audio_player.skin, "PLAY", False
    8/12/2009 11:47:01 AM: Executing: PLAY
    8/12/2009 11:47:01 AM: Leave Exec: False, audio_player.skin, play, False
    8/12/2009 11:50:02 AM: Enter Exec: False, audio_player.skin, , False
    8/12/2009 11:50:02 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    8/12/2009 11:50:02 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    8/12/2009 11:51:14 AM: WM_POWERBROADCAST: wParam=0
    8/12/2009 11:51:14 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    8/12/2009 11:51:14 AM: PrepareForHibernate: (Start)
    8/12/2009 11:51:14 AM: Enter Exec: False, audio_player.skin, "ONSUSPEND", False
    8/12/2009 11:51:14 AM: Que Exec: True, audio_player.skin, "ONSUSPEND", False
    8/12/2009 11:51:14 AM: Leave Exec: False, audio_player.skin, ONSUSPEND, False
    8/12/2009 11:51:14 AM: PrepareForHibernate: (After radio power's)
    8/12/2009 11:51:14 AM: PrepareForHibernate: Event/File Flush (end sub)
    8/12/2009 11:51:16 AM: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    8/12/2009 11:55:16 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
    8/12/2009 11:55:16 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    8/12/2009 11:55:16 AM: ---------------------------->
    8/12/2009 11:55:16 AM: ResumeFromHibernate: (start)
    8/12/2009 11:55:16 AM: ResumeFromHibernate: (Resuming = true)
    8/12/2009 11:55:18 AM: ResumeFromHibernate: (after resume delay)
    8/12/2009 11:55:18 AM: Enter Exec: False, audio_player.skin, "ONRESUME", False
    8/12/2009 11:55:18 AM: Que Exec: True, audio_player.skin, "ONRESUME", False
    8/12/2009 11:55:18 AM: Leave Exec: False, audio_player.skin, ONRESUME, False
    8/12/2009 11:55:18 AM: ResumeFromHibernate: Start tuners... Sirius, XM, & HD
    8/12/2009 11:55:18 AM: CheckResume: ResumeMusic=1 WasRadio=0
    8/12/2009 11:55:19 AM: ResumeFromHibernate: (End Sub)
    8/12/2009 11:55:19 AM: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    8/12/2009 11:55:19 AM: ResumeFromHibernate: (Hibernated = False)
    8/12/2009 11:55:26 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 11:55:26 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 11:55:26 AM: Que Exec: True, audio_player.skin, "VOL-", False
    8/12/2009 11:55:26 AM: Executing: VOL-
    8/12/2009 11:55:26 AM: Leave Exec: False, audio_player.skin, VOL-, False
    8/12/2009 11:55:27 AM: Enter Exec: False, audio_player.skin, "VOL-", False
    8/12/2009 11:55:27 AM: Que Exec: True, audio_player.skin, "VOL-", False
    8/12/2009 11:55:27 AM: Executing: VOL-
    8/12/2009 11:55:27 AM: Leave Exec: False, audio_player.skin, VOL-, False
    8/12/2009 11:55:27 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 11:55:27 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||VOL-", False
    8/12/2009 11:55:29 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:29 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:29 AM: Que Exec: True, audio_player.skin, "EXIT", False
    8/12/2009 11:55:29 AM: Executing: EXIT
    8/12/2009 11:55:29 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:55:29 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    8/12/2009 11:55:34 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:55:34 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:55:34 AM: Que Exec: True, menu.skin, "AUDIO", False
    8/12/2009 11:55:34 AM: Executing: AUDIO
    8/12/2009 11:55:34 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    8/12/2009 11:55:34 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    8/12/2009 11:55:40 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||NEXT", False
    8/12/2009 11:55:40 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||NEXT", False
    8/12/2009 11:55:40 AM: Que Exec: True, audio_player.skin, "NEXT", False
    8/12/2009 11:55:40 AM: Executing: NEXT
    8/12/2009 11:55:40 AM: Leave Exec: False, audio_player.skin, NEXT, False
    8/12/2009 11:55:40 AM: Enter Exec: False, audio_player.skin, , False
    8/12/2009 11:55:40 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    8/12/2009 11:55:40 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    8/12/2009 11:55:41 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:41 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:41 AM: Que Exec: True, audio_player.skin, "EXIT", False
    8/12/2009 11:55:41 AM: Executing: EXIT
    8/12/2009 11:55:41 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:55:41 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    8/12/2009 11:55:44 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:55:44 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    8/12/2009 11:55:44 AM: Que Exec: True, menu.skin, "AUDIO", False
    8/12/2009 11:55:44 AM: Executing: AUDIO
    8/12/2009 11:55:44 AM: Enter Exec: True, audio_player.skin, , False
    8/12/2009 11:55:44 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    8/12/2009 11:55:44 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    8/12/2009 11:55:49 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||NEXT", False
    8/12/2009 11:55:49 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||NEXT", False
    8/12/2009 11:55:49 AM: Que Exec: True, audio_player.skin, "NEXT", False
    8/12/2009 11:55:49 AM: Executing: NEXT
    8/12/2009 11:55:49 AM: Leave Exec: False, audio_player.skin, NEXT, False
    8/12/2009 11:55:49 AM: Enter Exec: False, audio_player.skin, , False
    8/12/2009 11:55:49 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    8/12/2009 11:55:49 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    8/12/2009 11:55:50 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:50 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:50 AM: Que Exec: True, audio_player.skin, "EXIT", False
    8/12/2009 11:55:50 AM: Executing: EXIT
    8/12/2009 11:55:50 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:55:50 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    8/12/2009 11:55:53 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:53 AM: Que Exec: True, menu.skin, "ONBTNPRESS||EXIT", False
    8/12/2009 11:55:53 AM: Que Exec: True, menu.skin, "EXIT", False
    8/12/2009 11:55:53 AM: Executing: EXIT
    8/12/2009 11:55:53 AM: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
    8/12/2009 11:55:53 AM: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
    8/12/2009 11:55:57 AM: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||QUIT", False
    8/12/2009 11:55:57 AM: Que Exec: True, exit_menu.skin, "ONBTNPRESS||QUIT", False
    8/12/2009 11:55:57 AM: Que Exec: True, exit_menu.skin, "QUIT", False
    8/12/2009 11:55:57 AM: Executing: QUIT
    8/12/2009 11:55:57 AM: Enter Exec: True, exit_menu.skin, "ONEXIT", False
    8/12/2009 11:55:57 AM: Queued: "ONEXIT"
    8/12/2009 11:55:57 AM: Shutdown: (1)
    8/12/2009 11:55:57 AM: Shutdown: (2)
    8/12/2009 11:55:57 AM: Shutdown: (3)
    8/12/2009 11:55:57 AM: Shutdown: (4)
    8/12/2009 11:55:57 AM: Plugin Manager: ALL Plugins unloaded.
    8/12/2009 11:55:57 AM: Shutdown: (5)
    8/12/2009 11:55:59 AM: Shutdown: (6)
    8/12/2009 11:55:59 AM: Shutdown: (7)
    8/12/2009 11:56:00 AM: Shutdown
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There's nothing apparently wrong with the debug log.. from a software/code stand point, hibernate and stand by are exactly the same thing... so if it works fine with hibernate it should work fine with standby, though I can tell you that hardware wise, hibernate will completely cut off power to the touchscreen, while standby MAY keep the power to the USB devices (depending on the hardware) -- this could be the cause of the problem itself..
    Maybe you want to try plugging the touchscreen through a powered HUB to see if it works with standby (hopefully the hub could cut power to it while in standby).
    Another thing to try is unplugging ALL THAT YOU CAN and leaving just the touchscreen and RR with not other USB (and maybe PCI) devices, and no other applications running, then try stand by to see if it resumes right.. if so, add everything back one by one testing standby to see if it breaks it -- this would tell you what's to blame.
    At last, the one thing you can TRY to do to solve the issue is to use DEVCON.EXE to disable the touchscreen with ONSUSPEND, then enable it again with ONRESUME... maybe this helps...
  7. #17
    Jan 2006
    will xport not do the same thing? I will look up decon as well
  8. #18
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I doubt XPort really disables the device (in device manager) as devcon can do -- it is definitely worth a shot.
  9. #19
    MySQL Error
    Oct 2004
    xport is for comports, i think... and prob shouldnt be messed with here
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  10. #20
    Jan 2006
    I read this about Devcon
    http://www.mp3car.com/vbulletin/faq-...de-devcon.html
    but it only seems to be for hibernate. anything for standby?
  1. Set RR resolution on resume from hibernation?
    By htsource in forum Road Runner
    Last Post: 08-08-2007, 04:05 PM
  2. Song stope on resume from hibernate
    By donde in forum Road Runner
    Last Post: 05-31-2007, 05:26 PM
  3. Replies: 22
    Last Post: 08-06-2006, 04:57 PM
  4. Trigger script/command on resume from hibernate?
    By tejesh83 in forum Software & Software Development
    Last Post: 10-24-2003, 08:05 PM
  5. M9000 display size on resume from hibernate
    By GingerPrince in forum Software & Software Development
    Last Post: 05-03-2003, 10:30 PM
