Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 49
Thread: Touchscreen problems in RR at resume from Hibernate
  1. #31
    Constant Bitrate jac1502's Avatar
    Jan 2006
    Right now I don't have anyway to pull the system out of stand by. The dsatx curenyly does this via the motherboard power swith. And I could only enter atandy as when I change screens I have to toggle back and forth from right to left click to get the buttons to highlight and function. I can set my keyboard to pull the system out of stand by but because its wireless will this even work?
  2. #32
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by jac1502 View Post
    Please note: how you bring the system OUT of standby (aka RESUME) is typically not important -- the questions/tests I asked you to try are in regards to GOING INTO standby (that is how you invoke standby). So you should be able to use the Touchscreen/wireless keyboard and the skin command on your tests.
    Ride Runner RR's Myspace
  3. #33
    Jan 2006
    When my system comes out of standby I can not get any buttons to highlight until I toggle the mouse icon. The mouse icon is part of the touchkit drives but I can turn it off
    Here is the mouse icon I am referring to
    Attached is a new debug log I created entering standby from using RR then coming out of standby with the same issues no left click function. I can move the mouse but it will not activate any buttons on press or even holding screen down. When I closed RR and restarted just RR it functioned fine again
    I was unable to find the file HW.txt you request and I searched all of the RR folder, what did I do wrong
    Sorry for the late replies I was out of town all weekend. I greatly appreciate your help and support!
    Attached Files Attached Files
  4. #34
    MySQL Error
    Oct 2004
    a quick look at the debug, riderunner resumed perfectly
    sounds like its all in ur touch screen drivers/utils
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #35
    Jan 2006
    I just dont get why if I exit out of RR the touchscreen works fine. Only in RR does it not function.
    any luck on get RR to restart my touchscreen via Devcon? I was unable to find the file Guino asked for
  6. #36
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RRConfig generates that file for configuration, but since you didn't find it, you can generate by executing this command from RR's folder:
    devcon find * > hw.txt
    then zip/post your hw.txt and I'll make you commands to disable/enable the touchscreen before/after resuming..
    PS: if the command above doesn't work, be sure that devcon.exe is in RR's folder (and you're in the folder as well).
  7. #37
    Jan 2006
    I found the file but it was directly in the C:\Program Files\road runner directory not in the config lang folder. Where should I place it when you modify it? File is attached.
    Thanks for all the help!
  8. #38
    MySQL Error
    Oct 2004
    how do u even exit rr? if touch screen dont work?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #39
    Jan 2006
    I have to hit the mouse icon which toggles fepb left to right click then I can use the screen I am on until I change to a new screen and I have to hit the mouse icon again. I might be able to make a video if that's not clear. Thanks
  10. #40
    MySQL Error
    Oct 2004
    well... that mouse icon stuff, is very spooky, and prob part of the problem
    typically, you want to disable all that stuff, and right click support
    just need basic touch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Set RR resolution on resume from hibernation?
    By htsource in forum Road Runner
    Last Post: 08-08-2007, 03:05 PM
  2. Song stope on resume from hibernate
    By donde in forum Road Runner
    Last Post: 05-31-2007, 04:26 PM
  3. Replies: 22
    Last Post: 08-06-2006, 03:57 PM
  4. Trigger script/command on resume from hibernate?
    By tejesh83 in forum Software & Software Development
    Last Post: 10-24-2003, 07:05 PM
  5. M9000 display size on resume from hibernate
    By GingerPrince in forum Software & Software Development
    Last Post: 05-03-2003, 09:30 PM
