Results 1 to 5 of 5
Thread: setvar
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    setvar
    in skin commands.txt:
    "SETVAR" - This allows you to set a global variable in RR. Those variables can be used for simple reference in the skin commands
    or be used to toggle between different groups of commands on skins (using BYVAR command).
    Example: "SETVAR;APPPATH;C:\MyApp\Myapp.exe"
    Then you can reference the variable APPPATH like this: "RUN;$APPPATH$"
    Note: SOME (but not all) settings in RR.INI can be changed in runtime.
    Note2: You can use ++ in this command when you'd like to delay reference to || on a command or label:
    [HL]Example1: Label Code: "$MYLABEL$" -- "SETVAR;MYLABEL;DATE++= ++TIME" (Displays DATE and TIME)[/HL]
    Example2: Command Code: "$MYCMD$" -- "SETVAR;MYCMD;AUDIO++PAUSE" (Executes AUDIO and PAUSE)
    The highlighted bit does not work. tried it manyy times in many scenarios. just doesnt work.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    there's nothing wrong with it -- you just made me spend time testing it again. It works fine, you probably just don't have a label large enough to fit the information for display.
    Ride Runner RR's Myspace
    Mar 2006
    Houston, TX
    Quote Originally Posted by guino View Post
    sry to upset, i still cant get it to work, and i know my labels large enough. its probably something im doing. ill keep looking at it, sorry to bother
    guino's Avatar
    Nov 2004
    Toronto, Canada
    maybe you're running an older/buggy version ? post your .skin file and I'll look at it.
    Dec 2008
    Got the same problem that SETVAR is not execute in label code
    Code:
    L03,202,369,370,24,#COL3R#,#COL3G#,#COL3B#,16,#FONT1#,"SETVAR;MYVAR;ABC||=$MYVAR$","CENTER"
    The label display nothing with above code
  1. using setvar with ||
    By chevyn8 in forum Road Runner
    Last Post: 09-25-2007, 09:32 AM
  2. MENU POPUP with - SetVar / SetLabel question ...
    By kolemieux in forum Road Runner
    Last Post: 07-19-2007, 02:35 AM
  3. SKin SetVAR question...
    By GuMiSZu in forum Road Runner
    Last Post: 05-08-2007, 10:27 AM
