When the winamp linein plugin is checked in RRConfig, the music resume function doesn't work at startup or out of hibernation. When the linein plugin is unchecked, music resume works perfectly.
I've reproduced this bug on more than one system now.
Printable View
Interesting... I'll have to look at it, but from what I understand, The linein plugin should not affect music playback.
Thanks Guino, it's an odd bug to say the least.
By the way, it's a problem with both the 2.95 and 5.13 version of winamp.
This is something I suffer from on 90% of my start-ups and makes RR virtually unusable.
Where is the check box in RRConfig, is it where you select what RR controls, i.e. Master volume? If it is then this isn't a fix for my problem because I have deleted the linein plugin from WA.
Depends which version of RRconfig you're running, but it's in the XM/Sirius options.
Or you can edit it right out of the RR.ini if you know what you're looking for.
