Results 1 to 5 of 5
Thread: Winamp Linein and Music Resume Bug
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    When the winamp linein plugin is checked in RRConfig, the music resume function doesn't work at startup or out of hibernation. When the linein plugin is unchecked, music resume works perfectly.
    I've reproduced this bug on more than one system now.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Interesting... I'll have to look at it, but from what I understand, The linein plugin should not affect music playback.
    Ride Runner RR's Myspace
    Jun 2007
    Thanks Guino, it's an odd bug to say the least.
    By the way, it's a problem with both the 2.95 and 5.13 version of winamp.
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    Quote Originally Posted by Machinehead View Post
    This is something I suffer from on 90% of my start-ups and makes RR virtually unusable.
    Where is the check box in RRConfig, is it where you select what RR controls, i.e. Master volume? If it is then this isn't a fix for my problem because I have deleted the linein plugin from WA.
    Jun 2007
    Depends which version of RRconfig you're running, but it's in the XM/Sirius options.
    Or you can edit it right out of the RR.ini if you know what you're looking for.
  1. Replies: 11
    Last Post: 10-16-2007, 09:56 AM
  2. Replies: 1
    Last Post: 08-31-2004, 06:19 AM
