Results 1 to 10 of 13
Thread: when i exit from rr, winamp doesn't close
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    i've set in the rrconfig "close embedded applications" but nothing
    i've set in the "exit" button closewinamp but nothing
    i'm thinking its dipend to the avs windows but i don't found solution
    using winamp 2.95 or winamp last version i have the same problem
    i look the task manager, winamp is open!!!
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    just something i spotted in your skin
    Quote Originally Posted by spidermunz View Post
    when vis was / is running and you exit rr. the vis window is still running ,not allowing
    winamp close correctly or open again.
    hope this helps a bit
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Jul 2006
    wow i never thought of that. it was getting pretty annoying having to go into task manager and manually kill it. ill do some testing now..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This could be an issue from a winamp plugin installed.. I have never seen this before.
    Ride Runner RR's Myspace
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    that was my thought at 1st
    Quote Originally Posted by guino View Post
    but the only plug's i have in mine anyway is the search .dll's nothing else .
    apart from the search its standard load.
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I only have the standard install of winamp 5.13 and sometimes I have to kill winamp in taskmanager too...........
    Leonardo Da Vinci
    Variable Bitrate kelmk's Avatar
    Aug 2007
    SF
    I have the same problem
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by kelmk View Post
    Read this: http://www.mp3car.com/vbulletin/road...n-rr-exit.html
    Wants to make it harder monkeyracer's Avatar
    May 2007
    Lakehood, CO
    I think it has something to do with the Visualizer. From what I've tested at least, it seems that when it's active on exit, it won't kill with RR, when it's not, it seems to work just fine.
    The killtask.exe that is in the post treetop777 posted does work though, but it's a seperate script that needs to be run to close it. It would be nice to have it kill the winamp.exe upon close without needing that external script.
    2007 Chrysler PT Cruiser TE
    Car PC Progress:
    View my
    Worklog
    Road Runner Skins
    Website
    Favorite thread EVER!
    Aug 2007
    SF
    Yeah you're right, turning vis off before exiting closes winamp. I tried adding "ONEXIT","VISU" but no go.
  1. Replies: 3
    Last Post: 11-23-2006, 10:14 AM
  2. use winamp 2.95 with RR still?
    By Will Albers in forum Road Runner
    Last Post: 11-14-2005, 06:08 PM
  3. Cant exit out of RR?
    Last Post: 11-10-2005, 03:00 PM
  4. Minimize winamp on RR Startup
    By Shelbrain in forum Road Runner
    Last Post: 05-26-2005, 01:09 AM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
