does winamp start?
Hi, I've tryed RR on my desktop PC and it worked just fine.
but when I'm trying it on my carputer in my car it won't even start.
The configer starts normaly.
no, nothing starts.
nothing happens when I double clicks the RoadRunner.exe file.
not even an error message ?
add this to RR.INI:
debugmode=true
then see if it creates a debug.txt file when you double click it -- in any case, please follow the install FAQ as you may be missing support files... do this specially if instead of actually installing the software, you simply copied everything from your desktop PC
Ride Runner RR's Myspace
can you start winamp by hand? if it runs, than start RR.
Is your soundcard working, without one winamp wil not start.
all settings in the RR confige-file correct?
Guido, i love the RR frontend, just finished my first skindesign with it and with the editor its real easy![]()
thanks, I'll try some of it when I got time.
I, have installed the software correctly and I have done the same configuration on both computers, but it will not work in my car.
Winamp runs great.
I tried to start it whit debug mode enabled, but I can't find the debug.txt file.
tried to instal the latest RR but it didn't help.
some more tips?
you have to check "Debug disbled." in the config file, than it says debug Enabled, this will create debug text.
Its not posting a missing file? i had a missing file error, think it was gdiplus.dll. A lot of programs use this file, so i copped the fille in rr directory and it works like a charm.
yes I did that, but no debug file.
thanks, I'll try your tip.
