When an indicator is turned on, and then off, you can not turn it back on again. If you reload the skin, it will show up as being on again.
I have confirmed this here with the following lines:
setind;CUSTOMLoadedCD1;On
setind;CUSTOMLoadedCD1;Off
(I also tried the original ! to define the custom indicator, just for
testing with the same results)
I execute the first line the indicator turns on
I execute the 2nd line, it goes off
executing the first line again, the indicator fails to light, no matter how many times you cycle it on or off. The only way to get it to appear, is to turn it on, and then do a skin reload.
I have tested this here extensively with multiple indicators. I also had BlueZX3 test this and he had the same results I am describing.
This only seems to effect custom indicators, as the shuffle, repeat, mute and such work correctly cycling on,off,on,off ect.
