Do you have some plugin or something that is supposed to call the exit_menu.skin?
I see this over and over:
4/12/2008 12:42:34 PM: Que Exec: True, exit_menu.skin, "||", False
like 200 lines of it....
Then there are all the lines at the end:
4/12/2008 12:42:37 PM: SDK command: ||
4/12/2008 12:42:38 PM: SDK command: ||
4/12/2008 12:42:39 PM: SDK command: ||
Something is definitely slamming Road Runner with external commands from a plugin or script, and the commands are empty on top of that. 8 Times in just over 2 seconds it looks like...
I would try to disable all plugins, and check the debug.txt as you turn each one back on.
Also, your Road Runner folder is named RoadRunner. It should be Road Runner (With the space). This has been known to cause issues with some plugins, scripts and such.
LinkBack URL
About LinkBacks
