Playlist display bug
I noticed that play lists saved with dashes or spaces in the name don't display coorectly in RR. RR will only display the text after the last space or -. I have tried 2 diff skins and the result is the same. is this a known issue? couldn't find any posts about this behavior. Thanks!
Yes, to over come this issue, you'll need to use an ("_") underscore instead
thanks! i will change the syntax my music app uses to store the play list names.
You can remove the "titlesafter" setting from RR.INI and it will display the whole filename containing dashes.
