Results 1 to 4 of 4
Thread: Playlist display bug
    Apr 2007
    Washington, DC
    I noticed that play lists saved with dashes or spaces in the name don't display coorectly in RR. RR will only display the text after the last space or -. I have tried 2 diff skins and the result is the same. is this a known issue? couldn't find any posts about this behavior. Thanks!
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, to over come this issue, you'll need to use an ("_") underscore instead
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Apr 2007
    Washington, DC
    thanks! i will change the syntax my music app uses to store the play list names.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can remove the "titlesafter" setting from RR.INI and it will display the whole filename containing dashes.
    Ride Runner RR's Myspace
  1. Replies: 4
    Last Post: 02-24-2009, 05:19 AM
  2. load playlist on startup
    By Moneyfink in forum RR Bug Tracker
    Last Post: 12-04-2007, 07:08 PM
  3. bug with playlist and line-in plugin
    By Passe in forum RR Bug Tracker
    Last Post: 11-08-2007, 12:10 AM
  4. Little issue i've been having with my playlist format
    By Sonicxtacy02 in forum Road Runner
    Last Post: 10-10-2007, 01:46 PM
