Results 1 to 8 of 8
Thread: can't launch map monkey embedded
    Newbie series2's Avatar
    Apr 2008
    I've read through the FAQ, and many of the other posts, But I still can't get Map monkey to launch embedded.
    If I set map monkey as an external GPS, it will run fine.
    It all used to work fine on my previous install.
    Software:
    Map Monkey ver. 1.1.348
    Road Runner Ver. 14.0.0.162 (installer)
    Clean install XP SP2
    Here's what I have tried so far.
    Set GPS app. as map monkey
    set path to map monkey executable
    Changed settings in settings.ini (map Monkey)
    Any help would be greatly appreciated.
    S2.
    P.S. I have made shure that the install folder is Road Runner (with a space)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    which skin ? see if you have destinator_gps.skin in the skin's folder -- otherwise it won't work. I'd recommend trying it with BMV2 first to check.
    Ride Runner RR's Myspace
    Newbie akula169's Avatar
    Aug 2006
    Exact same problem here. Using the CFX Green skin, and it does indeed have a desitinator_gps.skin
    Path inside the skin file is pointing to the correct MapMonkey exe. Should I post the destinator_gps.skin file?
    I've tried other skins as well. Same issue.
    GPS section of rr.ini:
    Code:
    [GPS]
    gpsmode=0
    mapmonkeypath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    gpspath=C:\DestinatorApps\Map Monkey\MapMonkey.exe
    gpsname=Navigation
    overspeed=75
    gpsport=0
    mappointmap=1
    mapcountry=United States
    mapcity=
    mapautozoom=true
    isunits=true
    usegpsserv=false
    gasfinderautorefresh=false
    Aw heck, I'm bored, so I'm posting the skin file to save some time in case it is requested:
    Code:
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    /Common buttons
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B01,0,12,135,78,"MAIN","Main Menu"
    B01,0,92,135,84,"AUDIO","Audio"
    B01,0,178,135,82,"VIDEO","Audio"
    B01,0,261,135,82,"GPS","GPS"
    B01,0,345,135,82,"LAUNCH","Apps"
    B01,0,429,135,85,"PHOCO","Phone"
    B00,0,519,77,82,"VOL-","Vol-"
    B00,78,519,68,82,"VOL+","Vol+"
    B00,146,519,72,82,"MUTE","Mute"
    /Date, Time, Volume
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L01,709,20,78,38,255,255,255,18,"GE Drover","TIME","CENTER"
    L02,703,54,85,19,19,46,76,12,"Arial:B","DATE","CENTER"
    L00,17,524,60,20,255,255,255,11,"Arial:B","=VOLUME","Left"
    L00,85,524,50,20,255,255,255,11,"Arial:B","VOLUME","Left"
    /, I, x, y, w, h, Code;INDICATORCODES
    I01,158,546,41,36,"MUTE:b"
    I02,665,16,23,29,"HEADING"
    I03,556,64,51,11,"ONLINE"
    /, IMG,XXX,XXX,XXX,XXX,"IMAGE.GIF|JPG|BMP",[LAYER]
    IMG,556,64,51,11,"online_indicator.gif",ON
    IMG,556,64,51,11,"online_indicator.gif",DOWN
    IMG,158,546,41,36,"mute_indicator.gif",ON
    IMG,158,546,41,36,"mute_indicator.gif",DOWN
    /Song LCD
    L10,150,15,503,31,255,255,255,20,"GE Drover","TRACKNUMBER||=. ||TRACKNAME","SCROLL-LEFT"
    L02,154,58,73,19,19,46,76,11,"Arial:B","STATUS","LEFT"
    L02,230,58,65,19,255,255,0,11,"Arial:B","CURRENTTRACKTIME","LEFT"
    L02,303,58,65,19,19,46,76,11,"Arial:B","TRACKTIME","LEFT"
    L02,374,58,33,19,19,46,76,11,"Arial:B","=ETA:","LEFT"
    L02,408,58,63,19,19,46,76,11,"Arial:B","MM;ETA","LEFT"
    L02,470,59,31,19,19,46,76,11,"Arial:B","=ETR:","LEFT"
    L02,506,59,48,19,19,46,76,11,"Arial:B","MM;ETR","LEFT"
    L10,610,48,55,31,255,255,0,18,"Arial:B","GPSSPD","RIGHT"
    L02,661,60,40,19,255,255,0,10,"Arial:B","=mph","LEFT"
    /Media Buttons
    B00,224,519,79,82,"RRPREV","Previous"
    B00,303,519,61,82,"PLAY",""
    B00,364,519,74,82,"RRNEXT",""
    B00,447,519,68,82,"MM;ZoomIn",""
    B00,517,519,66,82,"MM;ZoomOut",""
    B00,584,519,67,82,"MM;Destinate_Address",""
    B00,652,519,67,82,"MMDETACH||MM;CloseMapMonkey||LOAD;destinator_gps_full.skin;Map Monkey||RUN;C:\DestinatorApps\Map Monkey\MapMonkey.exe;Map Monkey",""
    B00,720,519,72,82,"MM;CloseMapMonkey||EXIT",""
    /, A, x, y, w, h, color;RGB
    A01,141,91,649,420,42,98,147
    END
    2000 Jeep Cherokee Limited 4WD
    Lilliput 7"
    VIA EPIA M10000, 512M, 80G WD
    Soundblaster Live! 24-bit
    Phoenix Gold SLD44 Line Driver
    Microsoft USB GPS
    Griffin Radioshark (reboxed)
    Apr 2008
    Hi guino.
    I was using the BMV2 skin that came with the installer, Destinator skin present in folder.
    I've just tried substituting an edited version of the BMV2 skin from an earlier install (known good), and that dosen't work either. Current version of the skin works fine on old install.
    S2.
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    didn't know anybody still used MapMonkey. The author 'Ninja Monkey' vanished a few years ago after threats of law suits etc.
    I thought most people had moved on to D6 / D7 as it uses a newer routing engine and looks nicer
    If you want to play cutting edge games have a look at Igo/Navngo and Sygic Drive
    Aug 2006
    fixed
    fixed my problem.
    Set config to External and set window name to "Map Monkey"
    All is well again
    Lilliput 7"
    Microsoft USB GPS
    Apr 2008
    In the end I gave up. I have set up the CF/D6 bodge - works well! I'm just going to edit the BMV2 skin now so that i have some control over winamp.
    Shame there's no uk maps for iGuidance - looks good.
    S2
    Apr 2008
    I have got Map Monkey to run embedded again. I went back to the .exe from 11-02-07, and all is good.
    Map monkey may be old and outdated, but it's good and stable with good speed cam support. and with a little fiddling D6 maps will work!
    Would be good if someone could make a fully D6 version of map monkey though.
    S2.
  1. Map Monkey Update
    By Ninja Monkey in forum Map Monkey
    Last Post: 05-12-2006, 01:25 PM
  2. Map monkey just closes - wrong maps
    By clemen in forum Map Monkey
    Last Post: 03-02-2006, 05:03 PM
  3. Map Monkey SDK
    By ESXprogrammer in forum Map Monkey
    Last Post: 06-28-2005, 01:04 PM
  4. Map Monkey POI updates, I need
    By gianal in forum Map Monkey
    Last Post: 04-26-2005, 03:20 PM
  5. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
