I am having the same problem. I read in another thread that this is caused by winamp not shutting down properly or fast enough before going into hibernation. There is supposed to be a winamp pluging but I could not find one.
hi!
i've got a problem with music resume after hibernation
if i load a list of music (list1), then close rr, and restart it, all is ok.
but if after this, i load new music, hibernation RR, when it resume,RR displays the text of songs of list2 ma plays list1, WHY?!
i use winamp 5.13 and the last version of RR.
thanks
hi.
thanks.
i have solved this problem.
in rr.ini set the 3 options of hibernation to true and than it will ok
hibernateaware=true
forcehibernate=true
hibernatereload=true
thanks... I wonder if that will fix my GPS not working after hibernation resume. I use Garmin spanner and after hibernation it loses connection. I have to manually reconnect spanner.
..and also xport can wake up your USB devices coming back from hibernation so you might be able to kill 2 birds with one stone..
I can't figure out how to get my USB18 to work with xport. From what I read, I dont think it is possible.
Has anyone figured out a way to come out of hibernate with Garmin Spanner and the GPS-18? I have the same setup and same problem. I suppose I'll have to see if Devcon and hibernate trigger can start and stop Spanner...
