Results 1 to 10 of 12
Thread: rr and winamp vis problem
    Oct 2007
    hi!
    i want to embedded a visu of winamp in RR
    i read a lot of posts, but nothing.
    i use winspy, the vis title is visualizer, in the RR config i try to put the class of visu and the title but nothing.
    in my skin i have an application tag also.
    what i can do and what is it wrong?
    thanks
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    First, and formost... you're going to have to give some more details..
    Like which visual, what window title(s) you have tried or used, which ver of winamp(does matter), then once you post them we can try to suggest what you need to either try or do.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Oct 2007
    hi!
    thanks
    winamp 5.13
    the visu name is classic spectrum analyzer http://www.winamp.com/plugins/details/165966
    i try with classic spectrum analyzer, with classicspectrum but nothing
    the window of visu is visualizer
    thanks
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Use "!Winamp Gen!AVS" (without the quotes)
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2007
    i put visuname=!Winamp Gen!AVS in rr.ini but nothing
    are there others modification i have to do?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    you have to open up winamp standalone and setup the visu, too.
    what skin?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2007
    i have a personal skin
    what i have to set in winamp?
    i set the visu that i want and stop. ok?
    other?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    The easiest way instead of retyping it is look in this DFX help file, uner the "How Do I..." section and it tell you how to set it up. It is for a different skin but the setup is same, just ignore the skin references...
    Attached Files Attached Files
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Oct 2007
    ok i will try.
    but i think that is for him visu
    Oct 2007
    ok.
    if i put a button like this "LOAD;audio_player.skin;;;Spectrum Analyser"
    it woks but in audio skin not in menu skin
    i want put visu in menu skin
    help : )
  1. Lsx Void 3.0
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 12-11-2013, 04:05 AM
  2. Three questions regarding RR, winamp, gps
    By Profozone in forum Road Runner
    Last Post: 02-18-2008, 08:53 AM
  3. Problem with WINAMP in RR - Needs help!
    By Visions in forum RR Bug Tracker
    Last Post: 08-18-2007, 01:03 PM
  4. RR and Winamp VIS...
    By DaPCWiz in forum Road Runner
    Last Post: 11-01-2005, 07:17 PM
  5. Winamp Playlists and RR
    By The Great Gatsb in forum Road Runner
    Last Post: 08-21-2005, 08:37 PM
