Results 1 to 10 of 17
Thread: cant play video within RR
    Nov 2007
    mplayerc plays well the same video outside of RR but nothing happens when i click play button in RR (BMV2 skin)
    can someone help please
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by qha_vn View Post
    Set the path to MPC in RRConfig and check (Check mark) built-in video (also in rrcomfig), then read this:
    http://www.mp3car.com/vbulletin/rr-f...look-here.html
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    get codecs, and make sure you can run the video in mp clasic
    Nov 2007
    i have set the correct path to mplayerc in RRconfig.
    mplayerc plays this same video very well when i started playing it in mplayerc
    the problem is that i can select the video in RR but nothing happens when i touched on play button, just nothing happens. is there a log where i can find if RR did something when i touch the button. same issue for DVD
    Feb 2007
    netherlands
    did you add the extensions in the rr config file: like .mp4,.mov,.avi
    Nov 2007
    yes i did add a row in rr.ini
    videofiles=.mp4,.mov,.avi
    Feb 2007
    netherlands
    you haven't checked the box that says use build in player that should be off.
    You can see the files and select them in RR video browser?
    You have done:
    - set path to mplayer classic
    - set the path to the files
    - set the extensions to use
    - unchecked use build in player
    and in mplayer itself it works, than it should also work in RR
    Dec 2007
    based on my experience, this is kinda erratic behaviour.. no real solution other than just trial and error.. i had it worked with built in player both checked and unchecked... Weird...
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by rijk View Post
    You have done:
    Not true, Built-in player should be CHECKED. MPC is not meant to play all video, just DVDs; the video is played in RR using a video API (if i'm saying that correctly) native to Windows which DO NOT depend on MPC, it maybe more dependent on WMP.
    Therefore, videos that play in MPC won't necessarily play in RR 'cause you are using two different payers.
    If the videos don't play in RR, you most likely have a CODEC problem; CHECK (check mark) built-in player and install a good CODEC pack like CCCP and your videos WILL play. (i would also make sure WMP is installed)
    Feb 2007
    netherlands
    If you ceck it you use the player of winamp.
    I use the mplayer for all the video formats, but i do have codecs.
    For dvd an external player (windvd) but mplayer can also play dvd's but then the sound isn't 5.1 but stereo
  1. Video freezes after RR upgrade
    By A-bloke in forum RR Bug Tracker
    Last Post: 09-09-2007, 09:31 AM
  2. Automatically play next video?
    By elvis98 in forum StreetDeck
    Last Post: 03-02-2007, 12:40 PM
  3. rr & winamp play same time/different videos?
    By turbocad6 in forum Road Runner
    Last Post: 01-12-2006, 03:40 AM
  4. Main menu with Video play on 2nd LCD
    By dougmorgan99 in forum Road Runner
    Last Post: 09-05-2005, 11:27 AM
