What skin are you using
ok the newest version of road runner will not embed mappoint I want to use mappoint because I can get it for free so what do I need to do to make it work right now if you set it up it will open but just as a window on top of road runner and road runner cannot control it it is not embedding into the program
thanks
jpbody
well if I use the default skin that comes with rr nothing happens at all when I click gps and if I use digital fx 4.0 and change the gps to be for mappoint then it does the whole open it like a window and not embed it if I use a 09/09/07 version of rr the mappoint works great but with the digital fx skin which is the one I want to be able to use the music database browser will not work then if I use the latest rr then the music database brower menu works but then mappoint will not embed I have checked the rr.ini between both versions of rr and both look the same as far as gps and pretty much everything else I had gone in and added the parts that were in the old one to the new one and still not working right
Have you tried using it with digital fx 3.0
actually I search for this for about the 10th time but a different way of saying it and I found one thread that had a beta roadrunner.exe on it I put it in and it works perfectly
Hey Jbody - i had the exact same problem about 3 months ago - its the new version of RR that has the problem - after about 2 weeks of banging my head against a wall i found a solution (though this is not a proven method of resolving issues).
Someone else had suggest to try this and it worked :
Have a read and i linked the old version of RR there :
http://www.mp3car.com/vbulletin/road...ml#post1208738
