Results 1 to 10 of 15
Thread: PLFORMAT not working ?
    Aug 2004
    Germany
    I can't change the playlist format on the fly with my autoit script. I guess the command is correct like this, isn't it ?
    Code:
    $rr=ObjCreate("RoadRunner.sdk")
    $rr.execute("PLFORMAT;%title%")
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'd suggest you make a debug log file to check what RR is receiving -- chances are that % in autoit may have a meaning in a string, so you may have to use %% or something. Again, this is just what I suspect could be the problem, looking at the debug log should be more revealing.
    Ride Runner RR's Myspace
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Actually, I just copied the code from the first post, and it is working perfectly for me. I copied the code from the poat, pased to a text file and saved as testpl.au3, double clicked it, and the list in RR changed instantly to show just the title of the song.
    Are you sure you are on a screen that is actually displaying a playlist, and not a Directory list or something else?
    PHP Code:
    My Fiero Build Thread
    Aug 2004
    Germany
    Ok, I downloaded the newest RR-Version (12-01-08), but it still doesn't work.
    I changed the code a bit to make sure that the playlist is selected:
    Code:
    $rr.execute("PLSEL")
    I started RoadRunner and clicked on the AUDIO button. After this I started the AutoIt script. Here's the resulting debug code:
    Code:
    07.12.2008 20:50:23: Executing: AUDIO
    07.12.2008 20:50:23: Leave Exec: Falsch, menu.skin, load;audio_player.skin;music, Falsch
    07.12.2008 20:50:26: Enter Exec: Falsch, audio_player.skin, , Falsch
    07.12.2008 20:50:26: Que Exec: Wahr, audio_player.skin, "SELPL", Falsch
    07.12.2008 20:50:26: Executing: SELPL
    07.12.2008 20:50:26: Que Exec: Wahr, audio_player.skin, "PLFORMAT;%title%", Falsch
    07.12.2008 20:50:26: Executing: PLFORMAT;%title%
    07.12.2008 20:50:26: Leave Exec: Falsch, audio_player.skin, PLFORMAT;%title%, Falsch
    As you can see I'm using a non-english windows version . falsch=false, wahr=true
    This is the code for the playlist in audio_player.skin. The playlist is shown, so I guess it's correct, but you never know:
    Code:
    S01,098,080,607,336,255,100,000,000,000,000,255,100,000,255,100,000,000,000,000,TRUE,24,"8Pin Matrix"
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Just curious about one thing.. what is your setting for ID3/Tag Reading ? If that's disabled or tags are unavailable, that won't work (meaning: won't have any effect).
    Aug 2004
    Germany
    Tag setting is Mix V2 with V1
    Could be that some songs are missing an ID3 tag. But RoadRunner shows songs without tags in the playlist. It just leaves the missing field (f.ex. artist or title) empty. So I didn't expect PLSEL to not work when there are song with missing tags in the playlist. Is that the case ?
    My RoadRunner installation shows "Artist - Title" in the playlist. I thought that's because of my setting in the RR.ini:
    Code:
    useid3=3
    showid3playlist=true
    showid3browse=true
    id3listformat=%artist% - %title%
    id3browseformat=%artist% - %title%
    But changing those fields to just %title% doesn't make a difference.
    I hope I'm not wasting your time, just because I'm misunderstanding the settings .
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try running RR directly with id3listformat=%title% and see if it shows any different than %artist% - %title% -- if it shows the same, it's probably just the tag information missing/invalid.
    Aug 2004
    Germany
    Putting just %title% still shows "Artist - Title" in the playlist.
    In my car I have some files which display as " - Title" in the playlist, artist missing. I'll have to check (soonest tomorrow) if those files really have no artist tag, or if there's a space saved in the field (declaring the field as not empty, know what I mean ?)
    Will RoadRunner ignore id3listformat/id3browseformat completely when there's just one mp3 in the playlist which is not tagged ? If that's the case, can't the code be changed that it shows <No Tag> instead, f.ex. "<No Tag> - Title" ?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If titlesafter= (blank) and you try to set the file format of songs without any Tag info, then RR will still show the file name as read from disk... this is likely what's happening to you... before you do any more testing with tag/list format PLEASE do verify your files are properly tagged or you won't have a way to define where the problem is.
    Also, if some tag fields are missing, RR will do its best to show the fields that do exist (it can't just "make up" data to fill empty fields).
    Aug 2004
    Germany
    Sooo, finally had the time to test.
    Cleared the playlist and added a tagged album to it. The year and genre are missing in the tag, but artist, album and songtitle are in there.
    mp3tag says "Version: ID3v2.3 (ID3v1 ID3v2.3)
    Windows explorer also shows the tags.
    I changed id3listformat and id3browseformat to just "%title%".
    When I start RoadRunner it still shows "ARTIST - TITLE" in the playlist and browser.
    No additional scripts or tools for RoadRunner are running.
    (BTW: tried WinAMP 2.95 and 5.03a, Windows XP Pro SP2)
  1. Infill G4 stopped working
    By haiminger in forum Centrafuse
    Last Post: 11-11-2007, 03:54 PM
  2. No USB Devices Working Out of the Blue
    By tbird2340 in forum General MP3Car Discussion
    Last Post: 10-17-2007, 12:21 PM
  3. -DisableWindowHooks not working - 1.1.0.0
    By Indy in forum StreetDeck Bug Reports
    Last Post: 07-31-2007, 09:40 AM
  4. SPV M700 / HTC P3600 not working with Phonecontrol
    By Tracert in forum PhoneControl
    Last Post: 07-13-2007, 11:16 PM
  5. Anyone currently working with 18f2550
    By lez in forum General Hardware Discussion
    Last Post: 11-03-2006, 08:44 AM
