Results 1 to 10 of 13
Thread: No List in Picviewer since RideRunner install
    Jun 2007
    Germany
    hi all,
    i install the Riderunner over my Roadrunner (v10.10.) Program.
    Since that, in my own Skin and in the Carwings Dynamic Skin, in the picviewer.skin is no List, no "DLPATH-Label" and no AlbumArt.
    After that, i de-install all and install my old RR Version. But, the same Result.
    Then i de-install again all to RR, and install only Riderunner. But, again, the same Problem.
    Whats this???
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    try adding "usedx = true " in rr.ini
    Live mp3Car Facebook Chat
    Jun 2007
    Germany
    its true... but no function...
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    when you reinstalled, did you recheck your "Init_Path" path in the "ImageViewer_Config.ini" file found in the ImageViewer folder in your RideRunner folder?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2007
    Germany
    I found the ImageViewer_Config.ini in the Carwings Dynamic Skin.
    Then typed-in the correct Folder.
    After that my RideRunner with Carwings Dynamic Skin embed my Notepad++ Programm
    But, when i start the imageviewer.exe per Hand, this would function.
    But, in my own Skin this files never exists! I would use the original Roadrunner function to view my Pics...
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    You should have a imageviewer folder in the RR folder, not the skinfolder? At least that is where mine is.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by toxic000 View Post
    hi all,
    Whats this???
    You likely just need to check/set the picspath= setting in RR.INI to point it to your pictures folder, like picspath=c:\mypics\ if you don't do that, the internal picture viewer (which is what you seem to be using) won't work.
    Ride Runner RR's Myspace
    Jun 2007
    Germany
    Uhhh, which for a stupid error of me!
    I have found now the reason- My defined Picture´s Folder has only Folders inside. I simply add a .txt File, and now the Folders are shown.
    To Info for Guino:
    I have now installed first the Roadrunner V.10.11.08, and then the Riderunner as Update. Then copied the .dll to system32 and reg.
    -all OK.
    Yesterday I installed the Full Setup -only Riderunner- and use the Debugfunction.
    -There whas one Mistake, -load this .dll in system32 Folder. After that, i searchd with WinXP-Search for this TLBINF32.DLL, and Win found nothing.
    Only as Info.
    Thanks for all your Help!
    Jul 2006
    Jervis Bay, NSW Australia
    I installed RideRunner version 02/02/2009 and imageviewer is NOT in the RR folder. It is in the Carwings skin folder. Copied it to RR folder and it now works, as long as there is at least one picture in the pictures folder. Originally my pics folder contained only subfolders. Added a dummy jpg file, and it now works.
    Max Perry
    Acer laptop Pentium M 735 1.7Ghz, 1.25Gb RAM, 64Gb solid state drive, Windows 7 32-bit
    Lilliput 8" LCD 829GL
    Garmin Mobile PC GPS
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I actually have a much improved version of this that i worked on. I'll get around to either posting it and/or updating the ver in the installer.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. CF card windows install
    By brendan in forum General Hardware Discussion
    Last Post: 07-03-2008, 04:07 PM
  2. Centrafuse 2.0 RC4
    By veetid in forum Centrafuse
    Last Post: 06-10-2008, 09:31 PM
  3. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
  4. Centrafuse 2.0 RC2
    By Ogold007 in forum Centrafuse
    Last Post: 05-21-2008, 03:59 PM
  5. Tinyxp vs nlite vs sensible install
    By geeky_hawkes in forum WinNT Based
    Last Post: 06-15-2006, 04:55 PM
