Results 1 to 7 of 7
Thread: Silabs USB Radio
    Low Bitrate JohnnySierra's Avatar
    Mar 2009
    Italy
    Silabs USB Radio
    I report some bugs:
    - Audio plays only on the front channels;
    - TP indicator doesn't work;
    - AF doesnt't work.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Those are not bugs.. just limitations of the implementation. You can probably make a directsound filter or use a winamp plugin to mix more than 2 channels though.
    Ride Runner RR's Myspace
    Mar 2009
    Italy
    Hello Guino,
    thanks for your reply.
    I hope that in the future you will extend your support for the Silabs radio.
    It's a great radio card.
    Mar 2009
    Italy
    Hi Guino.
    I hope you will improve the Silabs support for RR.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There are currently no plans to expand Silabs Radio Support, specially when most of the first world countries are already moving away from analog radio, which should only keep working for the next few years.
    Mar 2009
    Italy
    Ok.
    OT: I don't think that digital radio will come soon in Italy.
    DAB radio was experimented since 90's but at the moment it isn't diffused and it hasn't practical use.
    Mar 2009
    Italy
    I use Silabs radio activating the Jasper's line in plugin of Winamp http://home.hccnet.nl/th.v.d.gronde/...WA2/index.html.
    Whit this plugin the audio pass trough Winamp, so it's possible to use avs, equalizer, dsp, multi channel audio, etc..
    But there is a problem. When I set linein the audio is feeded also in the standard manner trough RR, and I have a sort of echo effect. I think that RR must disabled or muted the standard audio when linein is activated. Remember that Silabs sends audio via DirectSound and not a phisical audio input, so is not possible to mute it via mixer.
  1. Core Duo / Core 2 Duo Mini-ITX boards
    By RedGTiVR6 in forum General Hardware Discussion
    Last Post: 10-03-2010, 10:30 PM
  2. My USB Radio, can you make it work?
    By djchicago in forum Media Engine
    Last Post: 10-03-2010, 03:03 PM
  3. Silabs USB Radio
    By rev1richie in forum Car Audio
    Last Post: 10-08-2007, 03:53 PM
  4. Silabs USB Radio sound issue in RR
    By Nanner in forum Road Runner
    Last Post: 08-29-2007, 06:47 AM
  5. USB FM Radio with RDS/RBDS
    By skippy76 in forum General Hardware Discussion
    Last Post: 11-22-2004, 05:16 PM
