Results 1 to 10 of 13
Thread: App.Path not work
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    App.Path not work
    i have truble in vb6 code
    i have my converted plugin into F:\Programmi\RideRunner\Plugins\silabs folder
    if i call "msgbox App.Path" riderunner give me "f:\document and setting\spidermunz\desktop"
    i can't load my plugin because App.Path return to me a wrong folder
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Are you sure your using vb6?
    In vb6 App.Path=path here exe was executed from. vb.net is different and sounds more like what your describing.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Dec 2006
    italy, sardinia
    yes i using vb6 not vb.net
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    ha i knew i wasnt the only person with this issue! I uninstalled/reinstalled vb suite to get app.path to work correctly.
    Live mp3Car Facebook Chat
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Very odd...Mine has always worked correctly
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Dec 2006
    italy, sardinia
    Quote Originally Posted by Sonicxtacy02 View Post
    ok i try
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    It does seem flakey with RRPlugins though. ie whilst when it first starts it will actually contain the path the app (plugin is in) it will later on pick up either RR' path, the skin path or some other path, that is why I stick it in a variable when it first starts now.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Well....as I've said, I've never had a problem with the app.path thing..
    And with the upcomming plugin std change, plugins won't be storing any data in their folder (like they are not supposed to accod to win stds).....TBC
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    never had a app.path issue myself, but as mentioned above, it does reflect the location where the application is running from, NOT where the EXE is saved.
    Ride Runner RR's Myspace
    Dec 2006
    italy, sardinia
    i have solved the app.path problem
    but now i have this new problem:
    i have thios in my code
    Public Declare Sub SetMute Lib "usbsilabs.dll" (ByVal mute As Boolean)
    the plugin is running into riderunner but don't load the ussbsilabsdll
    some other command of the same plugin works perfectly
  1. How to make Winamp TV Plugin work with RR
    By ramez75 in forum Road Runner
    Last Post: 09-03-2010, 12:17 AM
  2. Stealthy surfing at work?
    By e_z_street in forum Off Topic
    Last Post: 10-07-2009, 02:30 AM
  3. Quality of work
    By BMVEE in forum RR Skins
    Last Post: 03-14-2007, 08:38 AM
  4. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 01:53 PM
  5. Replies: 4
    Last Post: 11-18-2002, 08:59 PM
