Results 1 to 10 of 13
Thread: Fmpreset
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    Angry Fmpreset
    Updated to the new version 4/1/09 now the command "FMPRESET;PRESET1" does not work anymore. It will save the frequency currently displayed by holding the button but it will not recall the saved frequency by clicking the button, instead it will override the preset.
    MySQL Error
    Oct 2004
    MGD, no one touched FMPRESET, fyi, u should look at the better way to save presets
    look at the carwings example
    and also, i just tested the command, works fine...
    remember this type of presets are stored in the FMPresets dir
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    It was working fine with the MARCH issue. I was running both, March and April. The last one is not working.
    MySQL Error
    Oct 2004
    like i said, i tested it, right when you posted.. it works fine... prob a skin issue, or file issue... is it saving the files in the fmpresets dir?
    with the CORRECT frequency in the file?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MGD
    MGD is online now
    MGD's Avatar
    Feb 2005
    Los Angeles
    I used the installer and there is no fmpresets Dir. Should the installer create one?
    Like I said, my skin was working fine with the March issue.
    MySQL Error
    Oct 2004
    NO, the installer doesnt create it
    if it was working in MARCH, id think u would have the FMPRESETS dir
    (but i forget when filemanager took control)
    That is the problem... u need to create the dir FMPresets, and copy all ur presets there...
    i feel this was mentioned...
    I dont use this OLD method to save presets, like i said look at carwings radio player skin...
    I will add dir creation to code
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    FOR THE RECORD:
    copy your .fm preset files to a dir FMPrests (example, C:\Program Files\RideRunner\FMPresets)
    since the internal file manager keeps them in a directory now or since 3/11/09
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    grab the HOT FIX
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2007
    Export, PA
    it's little things like this that reinforce my way of going about presets and things of that nature, things that can be saved as a simple string.......things that can just as easily be saved as a variable in skin.ini
    i dont doubt that it works, but i also prefer to have all of my main settings and such be all stored in 1 ini, instead of independant files when possible
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    MySQL Error
    Oct 2004
    yes... ALL my presets are saved in skin.ini
    look at the radio skin in carwings reference skin
    I DONT USE FMPRESET, and i recomend NOT using it, but to use the method in
    the reference skin...
    me too want things consolidated
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Save RDSName like FMPRESET ??
    By GF-ler in forum RR Skins
    Last Post: 10-30-2008, 04:07 AM
