Results 1 to 9 of 9
Thread: Possible bug in command execution ? (ExecTBL.ini)
    Aug 2004
    Germany
    This is some code in my ExecTBL.ini
    Code:
    /, SETTINGS SCREEN
    "SET_UPD_MUSIC","BYVAR;SYGIC_PAUSEWINAMP;SETVAR;SET_MUSIC;$OPTIONS_21$<<SETVAR;SET_MUSIC;$OPTIONS_22$"
    "SET_UPD_SWITCH","BYVAR;SYGIC_SWITCHSCREEN;SETVAR;SET_SWITCH;$OPTIONS_31$<<SETVAR;SET_SWITCH;$OPTIONS_32$"
    "SET_UPD_DELAY","EVAL;SET_TMP;strcomp("$SYGIC_SWITCHBACKTIME$";"0")||BYVAR;SET_TMP;SETVAR;SET_DELAY;$OPTIONS_411$$SYGIC_SWITCHBACKTIME$$OPTIONS_412$<<SETVAR;SET_DELAY;$OPTIONS_42$"
    "SET_UPD_OSK","BYVAR;HOSK_DEFAULT;SETVAR;SET_HOSK;$OPTIONS_61$<<SETVAR;SET_HOSK;$OPTIONS_62$"
    "SET_UPD_MEDIABASE","BYVAR;MEDIABASE_REFRESHMODE;SETVAR;SET_MEDIABASE;$OPTIONS_71$<<SETVAR;SET_MEDIABASE;$OPTIONS_72$<<SETVAR;SET_MEDIABASE;$OPTIONS_73$"
    "SET_SAVE","SAVETOSKIN;SYGIC_PAUSEWINAMP;$SYGIC_PAUSEWINAMP$||SAVETOSKIN;SYGIC_SWITCHSCREEN;$SYGIC_SWITCHSCREEN$||SAVETOSKIN;SYGIC_SWITCHBACKTIME;$SYGIC_SWITCHBACKTIME$||SAVETOSKIN;HOSK_DEFAULT;$HOSK_DEFAULT$||SAVETOSKIN;MEDIABASE_REFRESHMODE;$MEDIABASE_REFRESHMODE$"
    "UPDATEIND_SETUP","SET_UPD_MUSIC||SET_UPD_SWITCH||SET_UPD_DELAY||SET_UPD_OSK||SET_UPD_MEDIABASE"
    The last command throws an error. Here's part of the log when it's executed:
    PHP Code:
    08.06.2009 09:12:14Que ExecWahrmenu2.skin"UPDATEIND_SETUP||LOAD;options.skin"Falsch
    08.06.2009 09
    :12:14ExecutingSET_UPD_MUSIC
    08.06.2009 09
    :12:14Command not executedSET_UPD_MUSIC
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"ONCOMMANDINVALID"Falsch
    08.06.2009 09
    :12:14ExecutingONCOMMANDINVALID
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SET_UPD_SWITCH||SET_UPD_DELAY||SET_UPD_OSK||SET_UPD_MEDIABASE"Falsch
    08.06.2009 09
    :12:14ExecutingBYVAR;SYGIC_SWITCHSCREEN;SETVAR;SET_SWITCH;Bildschirm bei Anweisungen nicht wechseln<<SETVAR;SET_SWITCH;Bei Anweisungen zum GPS Bildschirm wechseln
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SETVAR;SET_SWITCH;Bei Anweisungen zum GPS Bildschirm wechseln"Falsch
    08.06.2009 09
    :12:14ExecutingSETVAR;SET_SWITCH;Bei Anweisungen zum GPS Bildschirm wechseln
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SET_UPD_DELAY||SET_UPD_OSK||SET_UPD_MEDIABASE"Falsch
    08.06.2009 09
    :12:14Executing: EVAL;SET_TMP;strcomp("2";"0")
    08.06.2009 09:12:14Que ExecWahrmenu2.skin"BYVAR;SET_TMP;SETVAR;SET_DELAY;$OPTIONS_411$$SYGIC_SWITCHBACKTIME$$OPTIONS_412$<<SETVAR;SET_DELAY;$OPTIONS_42$"Falsch
    08.06.2009 09
    :12:14ExecutingBYVAR;SET_TMP;SETVAR;SET_DELAY;Nach Anweisungen 2 Sekunden warten<<SETVAR;SET_DELAY;Nach Anweisungen sofort zurück wechseln
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SETVAR;SET_DELAY;Nach Anweisungen 2 Sekunden warten"Falsch
    08.06.2009 09
    :12:14ExecutingSETVAR;SET_DELAY;Nach Anweisungen 2 Sekunden warten
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SET_UPD_OSK||SET_UPD_MEDIABASE"Falsch
    08.06.2009 09
    :12:14ExecutingBYVAR;HOSK_DEFAULT;SETVAR;SET_HOSK;Standard Bildschirmtastatur verwenden<<SETVAR;SET_HOSK;Kompakte Bildschirmtastatur verwenden
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SETVAR;SET_HOSK;Standard Bildschirmtastatur verwenden"Falsch
    08.06.2009 09
    :12:14ExecutingSETVAR;SET_HOSK;Standard Bildschirmtastatur verwenden
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SET_UPD_MEDIABASE"Falsch
    08.06.2009 09
    :12:14ExecutingBYVAR;MEDIABASE_REFRESHMODE;SETVAR;SET_MEDIABASE;Bei DB Refresh alle Tags importieren<<SETVAR;SET_MEDIABASE;Bei DB Refresh keine Tags speichern<<SETVAR;SET_MEDIABASE;Bei DB Refresh nur neue Tags lesen
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"SETVAR;SET_MEDIABASE;Bei DB Refresh nur neue Tags lesen"Falsch
    08.06.2009 09
    :12:14ExecutingSETVAR;SET_MEDIABASE;Bei DB Refresh nur neue Tags lesen
    08.06.2009 09
    :12:14Que ExecWahrmenu2.skin"LOAD;options.skin"Falsch
    08.06.2009 09
    :12:14ExecutingLOAD;options.skin
    It says that the command SET_UPD_MUSIC is invalid. If I remove the command SET_UPD_MUSIC it throws the same error for the next command (SET_UPD_SWITCH).
    I then just changed the command "UPDATEIND_SETUP" by adding an empty command to the beginning
    Code:
    "UPDATEIND_SETUP"," ||SET_UPD_MUSIC||SET_UPD_SWITCH||SET_UPD_DELAY||SET_UPD_OSK||SET_UPD_MEDIABASE"
    Then it works and doesn't throw an error:
    PHP Code:
    08.06.2009 09:15:12Que ExecWahrmenu2.skin"UPDATEIND_SETUP||LOAD;options.skin"Falsch
    08.06.2009 09
    :15:12Executing:
    08.06.2009 09:15:12Que ExecWahrmenu2.skin"SET_UPD_MUSIC||SET_UPD_SWITCH||SET_UPD_DELAY||SET_UPD_OSK||SET_UPD_MEDIABASE"Falsch
    08.06.2009 09
    :15:12ExecutingBYVAR;SYGIC_PAUSEWINAMP;SETVAR;SET_MUSIC;Bei Anweisungen Lautstärke reduzieren<<SETVAR;SET_MUSIC;Bei Anweisungen Musik pausieren
    08.06.2009 09
    :15:12Que ExecWahrmenu2.skin"SETVAR;SET_MUSIC;Bei Anweisungen Lautstärke reduzieren"Falsch
    08.06.2009 09
    :15:12ExecutingSETVAR;SET_MUSIC;Bei Anweisungen Lautstärke reduzieren
    Is that a bug, or am I doing something wrong ? I'm using the 06-01-2009 release. I just added this command, so I can't tell since which version this happens.
    MySQL Error
    Oct 2004
    EXECTBL IS forward translation only...
    so... UPDATEIND_SETUP cannot translate into "SET_UPD_MUSIC"
    (technical reasons)
    in the 1st command, since its after in the list
    move the UPDATEIND_SETUP line before SET_UPD_MUSIC
    try that...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    For unseen reasons, this is sorta funny, eh mitch...hehe
    He actually made an attempt to fix this but ended up making it way worse, and decided that its not really broken b/c most skinners know that they have to make it forward translate.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Aug 2004
    Germany
    Oooookeyyyy, can this be changed ? I actually think that's a really strange behaviour.
    And why does it work with the empty command ? As far as I understand your argumentation this shouldn't work either, because UPDATEIND_SETUP is still after SET_UPD_MUSIC in the list ?!
    MySQL Error
    Oct 2004
    I didnt make it worse, i MADE IT BETTER
    but took it out, because someoone could make a exectble that loops forever
    and hangs RR....
    because, the commands after || are seperated, requeued, and thus go though the translation loop from the top
    its always been this way... I wanted the order not to matter, but we found in cases some bad exectble coding would loop forever translating... think about it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Mitch had asked that too,as he had no idea that it worked the way it currently does.
    In an ideal world, you should be able to translate any command in that table, reguardless of where its at...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Aug 2004
    Germany
    Quote Originally Posted by mitchjs View Post
    and hangs RR....
    Didn't think about that. Still think it would be better if it's not just forward execution. Sadly I don't have a clever idea to avoid loops. But I'll get back to you when I have one .
    MySQL Error
    Oct 2004
    konrad, i did have it that order not matter, and it didnt take long for G to show me an example of what people have already in a skin, and it would cause a loop
    i do have some ideas... but for now, im gonna slide it a bit back into my memory, because it is working as it always has...
    im focusing now, on two other issues...ill revisit it im sure
    thanks for posting, because when it happend to me, thats when i learned that order mattered!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Tiss... maybe if you actually used the SW outside of testing things, ya know...like in a car...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. StreetDeck Bug Reporting System
    By RedGTiVR6 in forum StreetDeck
    Last Post: 12-10-2007, 03:07 PM
  2. ExecTBL.ini bug?
    By hematec in forum RR Bug Tracker
    Last Post: 11-20-2005, 09:20 AM
  3. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  4. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
