Results 1 to 10 of 19
Thread: [RESOLVED] Plugin manager does not update labels when using iList
    Jun 2008
    Atlanta, GA
    I'm working on the plugin manager screen for my skin, working off of the carwings dynamic lite as a base. I noticed that if I leave the list as a standard DL then the associated plugin labels (version, description, status, etc.) get updated as I click on different items in the list. However, if I change the list to be an iList those labels no longer get updated.
    I'm using the same label codes as are used in carwings:
    L,710,175,80,30,#LCDR#,#LCDG#,#LCDB#,18,#LCDFont#, "pluginmgr|version|$DLPLUGINNAME$","LEFT"
    My guess is that somewhere in the plugin it updates $DLPLUGINNAME$ with the currently selected item name on each click of the list, but maybe not on every click of an iList?
    I haven't been able to find that variable anywhere in the exectbl or .ini files for carwings, so I apologize if there's some simple explanation/solution I'm missing...
    Thanks.
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    snap i found this problem way back when mitch built it, i have managed to get 1 out of 6 comp's to accept ilist in plugin manager, but it was short lived, i did bring this to mithc's attention , and we have found no solution for it as yet, but it only seems to be a very small amount of users that have this problem, as no 1 else apart from you has pubilcly mentioned this. i have even re-built 3 pc's and still get the same result,but if you select in the list then refresh the list you will see the labels update ,||pluginmgr;list
    but your right the PI dose up-date the $DLPLUGINNAME$ ondirclick,
    sorry i know its no help to you but just wanted to add that your not alone,
    MySQL Error
    Oct 2004
    ok, here how it works
    the SKIN must me named: "pluginmgr.skin" and a DL type
    and when a MouseDown of a item ("ONDIRCLICK" happens)
    dlpluginname gets set
    if skin isnt named that, it wont happen
    i dont know anything about ilist... if u send me the .skin file with ur change to ilist, i can eval
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    and thats how i have it direct copy from carwings, no changes made except adding ilist line
    MySQL Error
    Oct 2004
    show me the line please
    i have found a bug in RR, that if the TYPE is "LST" it is tried to get ID3 for
    since its not a song, it gets corrupted in the internal list
    i can fix... but i need to fully understand lists
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    /, IL, LIST, SelImg, UnselImg, EndImg, LimitMode, Drag, MaxSpeed
    IL,DL,transparent.bmp,sel.bmp,end.bmp,0,50,60
    MySQL Error
    Oct 2004
    thanks!
    i have a test build, i would like you to test it... do u know where to find me?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    well done mitch all good
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    Ondirclick works ,but I noticed that the up/down buttons don't update labels could it be the same bug
    MySQL Error
    Oct 2004
    carputer1, those look like they never worked
    geeze, i got some bad beta testers, and ME too!!!
    you would think i would try the arrows... not just click on the damm list
    i will figure out what to fix
    and post u a new build
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. .net Bluetooth Mobilephone Plugin
    By lambosprit in forum RR Released Plugins
    Last Post: 02-09-2012, 10:46 PM
  2. Chuck's Skins lots of pics Update 7-16-07
    By Chuck in forum RR Released Skins
    Last Post: 11-10-2011, 08:22 PM
  3. Source Help: New labels dont update in flash
    By Sonicxtacy02 in forum Road Runner
    Last Post: 03-23-2007, 12:09 PM
  4. Wireless Connection Manager Plugin
    By buurin in forum Centrafuse
    Last Post: 02-07-2006, 05:34 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
