Results 1 to 2 of 2
Thread: ONSUSPEND/ONRESUME Problems with Volume and Relaiscard Plugin. and other
    Jun 2007
    Germany
    Hello,
    I build my RR Skin in a virtual PC - on this System all my Skin Commands works fine.
    In the CarPC, i have with the same RR Version a couple of problems, with this commands:
    1.
    "onsuspend","SETVOL;MASTER;10||k8055_do_reset_bit_ 1"
    "onresume","k8055_do_set_bit_1"
    (They are in my own exectbl - a problem?)
    the Setvol Command function in my virtual PC- on CarPC it has no function. On CarPC i use a x-Fi Soundcard, where the Master channel use the Name "W-gabestr.". Is this the Problem?
    The Setvol Command for the Master Line has only on "ONSUSPEND" no function- in the Skin, on the Road it goes perfect.
    The Commands "k8055_do_reset_bit_1" & "k8055_do_set_bit_1" works also not, for this the debug.txt write:
    29.06.2009 19:40:34: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    29.06.2009 19:40:34: PrepareForHibernate: (Start)
    29.06.2009 19:40:34: Enter Exec: Falsch, mixer.skin, "ONSUSPEND", Falsch
    29.06.2009 19:40:34: Que Exec: Wahr, mixer.skin, "ONSUSPEND", Falsch
    29.06.2009 19:40:34: Que Exec: Wahr, mixer.skin, "k8055_do_reset_bit_1", Falsch
    29.06.2009 19:40:34: Executing: k8055_do_reset_bit_1
    29.06.2009 19:40:34: Command not executed: k8055_do_reset_bit_1
    29.06.2009 19:40:34: Que Exec: Wahr, mixer.skin, "ONCOMMANDINVALID", Falsch
    29.06.2009 19:40:34: Executing: ONCOMMANDINVALID
    29.06.2009 19:40:34: Leave Exec: Falsch, mixer.skin, ONCOMMANDINVALID, Falsch
    29.06.2009 19:40:34: PrepareForHibernate: (After radio power's)
    29.06.2009 19:40:34: PrepareForHibernate: Event/File Flush (end sub)
    29.06.2009 19:40:36: WM_POWERBROADCAST: wParam=PBT_APMSUSPEND
    29.06.2009 19:41:13: WM_POWERBROADCAST: wParam=PBT_APMRESUMEAUTOMATIC
    29.06.2009 19:41:13: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    29.06.2009 19:41:13: ---------------------------->
    29.06.2009 19:41:13: ResumeFromHibernate: (start)
    29.06.2009 19:41:14: ResumeFromHibernate: (Resuming = true)
    29.06.2009 19:41:14: WM_POWERBROADCAST: wParam=PBT_APMRESUMESUSPEND
    29.06.2009 19:41:15: ResumeFromHibernate: (after resume delay)
    29.06.2009 19:41:15: Enter Exec: Falsch, mixer.skin, "ONRESUME", Falsch
    29.06.2009 19:41:15: Que Exec: Wahr, mixer.skin, "ONRESUME", Falsch
    29.06.2009 19:41:15: Executing: k8055_do_set_bit_1
    29.06.2009 19:41:15: Command not executed: k8055_do_set_bit_1
    This Commands are from the Relaiscard K8055 Plugin - they work in the running RR on the Road. But no chance on ONSUSPEND/ONRESUME.
    Goes ONSUSPEND/ONRESUME in all *.skin Files, or only in menu.skin?
    2.
    My old Problem with picviewer.skin. I doŽnt use a Imageviewer.exe or something else- simply a Skin, with the standart picviewer Directory List, a Album Art and two Buttons. In virtual PC it shows me always the directory List. In the CarPC only one time, after a full restart from Windows XP.
    In the List path are folders and files, the skin file doŽnt use iList and the paths in RRconfig set right.
    My RR Version is from April09- for my Problems i had no Bug-Fix seen in RR changelog.
    Many little Problems, i hope one can help
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, does not matter what screen your on...
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
