Results 1 to 10 of 10
Thread: Lockup with screen corruption
    Low Bitrate JackB's Avatar
    Aug 2006
    Kirkland, Washington, United States
    > 1. Version of RideRunner being used (should really be using the lastest).
    This has been a problem for a while now, since it was RoadRunner, but it seems to be happening more often.
    2. Skin Being used (Best to have tested with more than one skin, esp the Default : Carwings)
    Carwings, BMV2
    3. Full description of problem including any steps taken by yourself to resolve it.
    Only when running RR I get screen corruption and the machine locks up. See photo. I used no front end and things worked fine (but what a pain in the ***). This happens after a random time running RR. Happens after a full boot or a resume. Happens wether I've got GPS running or not, Sirius and HD Radio hooked up or not. It'll happen in whichever subsystem/program I'm using. (WinAmp, Sirius, Movies..) It's okay when it happens in Sirius because, even though I can no longer change channels nor volume, the sound buffer doesn't loop and annoy the crap out of me until I can pull over and turn the car off 'til the powersupply times out and cuts power.
    4. Attach a zip file with the following
    debug.txt
    rr.ini
    resume.ini (If available)
    ExecTBL.ini
    SRCache.ini
    5. I have used the search function of the forum to see if the problem has occured before.
    <Enter YES here if and only if you can say yes to the above>
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    43
    i doubt this has anything to do specifically with RR. It looks like a hardware/driver issue relating to your video card.
    Live mp3Car Facebook Chat
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Could be the screen or video card doesn't like having the gamma settings changed.
    Aug 2006
    Quote Originally Posted by Sonicxtacy02 View Post
    Well, I tend to agree with that in spirit... The issue, though, is that it only happens while RR is running.
    Quote Originally Posted by Enforcer View Post
    That's possible, but it's not happening when I change it manually with the slider in Carwing and it seems to happen randomly at all times of the day.
    MySQL Error
    Oct 2004
    the slider is, DIMMER...doesnt do anything with video card settings
    like gamma does...
    but that sure does look like HW issue
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    how about CPU Temp...
    RAM ISSUE?
    hammer the ram, with memtestx86
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2006
    I'll look into gamma.
    CPU temp is okay.
    I can hammer the memory.
    MySQL Error
    Oct 2004
    just disable gamma, in rrconfig
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Aug 2006
    So, disabling gamma didn't do anything, but if I keep it minimized I don't get the lock up. I'm guessing it's a GDI issue, possibly. Haven't had time to look into the config to see what options I have.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This could be an issue with DirectX, GDI+ and/or video drivers/memory, though I have never seen anything like it. I would suggest to check the DirectX version and checking if there's a newer video driver available for you to install. Other than that you can try to set fastmode=0 and usedx=false in RR.INI and see if it does it or not (it will disable ilists/gdi+/directx).
    Ride Runner RR's Myspace
  1. Replies: 14
    Last Post: 09-11-2008, 03:14 PM
  2. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 10:56 AM
  3. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 04:31 AM
  4. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 12:20 AM
  5. Replies: 4
    Last Post: 01-26-2006, 02:35 AM
