Results 1 to 5 of 5
Thread: RR volume mapping
    Jun 2007
    NJ
    RR volume mapping
    I just reinstalled my system with an rtm copy of win7. Also, I have an XFi using the latest drivers. Either one of these could be my problem, but here is the issue. When I load up RR, I'm not able to lower the volume through RR (it won't go lower than whatever it started at). Also, I'm using 4 channels through the xfi drivers, and when I try to raise the volume, it only raises the front 2 channels, not the rear 2 channels.
    This is odd because when the volume slider for Windows properly moves, but only the front channels are affected. When I try to move the volume slider in Windows manually, it correctly raises the rear channels as well!
    This happens in all three available volume mappings: All, Master, and Volume
    If anyone could raise some insight into this problem that would be great. Thanks!
    Sep 2005
    Auckland, NZ
    Lightbulb
    In your speaker settings (Control Panel -> Sounds ) there is usually a setting which allows you to move all sliders simultaneously. Have you checked if this is enabled?
    Jun 2007
    NJ
    This option doesn't seem to exist in Windows 7, or if it does, then xfi drivers have disabled it.
    MySQL Error
    Oct 2004
    when in vista/win7, RR master volume is the same master volume windows would use... its done via Audio Endpoint enumeration...
    you might have more then 1 endpoint...
    but with out me having that X-Fi, we may never know
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Aug 2009
    Quote Originally Posted by kaerf View Post
    enen. i agree.
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. A few issues left with RR
    By kelmk in forum Road Runner
    Last Post: 11-03-2008, 03:27 PM
  3. Volume Slider
    By garto in forum Road Runner
    Last Post: 05-13-2007, 01:11 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
Tags for this Thread
