Results 1 to 5 of 5
Thread: "onsuspend","MAIN"
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    "onsuspend","MAIN"
    since ilists sometimes do not resume i have set in the exectbl.ini to :
    "onsuspend","MAIN"
    it works fine if hibernate is trggered by the powersupply or windows..but when hibernate is triggered by RR via "HIBERNATE" (not directly , but from an "exit.skin"), 2 seconds after resuming rr suddenly closes!!. it works ok when "HIBERNATE" is sent directly (via skintool for example)
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You may want to try a resume delay. This issue is very hard to debug because it's basically DirectX loosing the loaded surfaces for the list -- RR has detection to re-build them after hibernate/standby (but sometimes DirectX will not re-create the surfaces anyway).
    Ride Runner RR's Myspace
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I think that he understands that, but is saying that there is a different issue when calling the hib cmd from w/i RR.
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This is weird because the same exact code used on Hibernate through the exit menu, is executed when sending it through skintool.
    However, if through skin tool it works, I would like you to change the "HIBERNATE" command in the exit menu to this:
    "RUNQ;$RRPATH$exec.exe|hibernate"
    Let me know what happens..
    Guino.
    Apr 2006
    Greece
    i will just out of curiosity..but i changed to "onsuspend","reloadskin" and it does the same thing, so no issues..i am away for a few days i will try when i get home..thanks guys
