VLCVidRR Bug in fullscreen with FULL a/r
There's a problem with VLCVidRR and leaving fullscreen when aspect-ratio is FULL.
I've enabled auto-fullscreen in RoadRunner. This is working fine, also leaving fullscreen when moving the mouse. But I use a remote to control the pc. I'm not moving the mouse (leaving fullscreen) and then press an EXIT-button.
I execute the command EXIT directly with my remote when RR is in fullscreen mode.
This is working fine in fullscreen for every aspect I select (+16:9,-16:9,...) except FULL. Then the movie stops but the screen stays black.
I know that VLC is still running, because with this plugin the VLC player is always showing a grey line at the bottom.
The bug doesn't happen when FULL aspect ratio is selected and RR is NOT in fullscreen mode. RR then leaves the screen as it should.
1. Could this please be fixed ?
2. What's that grey line on the bottom for, anyway ? Can this be removed ?
