Results 1 to 10 of 16
Thread: Riderunner failing to split combined commands from plugin into separate commands
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    As title says.
    RideRunner seems to have an issue with splitting a double command from the Trafficam plugin.
    This command worked fine in RoadRunner 13/10/2008 but doesn't work in RideRunner 19/08/2009 and I assume the lastes version as JohnWPB brought this to my attention.
    Command that is sent from the plugin is "load;trafficcam_search.skin||rrtc_onclclick" this is after the plugin intercepts an onclick event. ProcessCommand is 3.
    As I said this work in RoadRunner and other multiple commands seem to work fine from the plugin.
    It may have something to do with the onclick event being hijacked (or not)
    Edit to add Debug.txt
    Attached Files Attached Files
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Y do know that we now have an official Bug/feature management section? Miss the sticky did ya?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Which doesn't work. Or at least doesn't let me access it. Which you well know.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I have PM'd Goce once again to look into the permissions on it... I have not heard back yet. It's strange how you can not see it as a moderator, but standard level users have been posting in there. I bet he set the permissions for Blue, Guino, Mitch and I manually, and set permissions for the standard level, and forgot to add it for all mod's or something.
    My Fiero Build Thread
    MySQL Error
    Oct 2004
    E, i just noticed this is
    20/10/2009 01:22:53: Start -- Version: 01/08/2009
    20/10/2009 01:22:53: OS Type: Windows XP
    try it on latest
    does, it load the skin?
    i did "load;radio_player.skin||RTune;106.1" and it loads skin, and tunes to 106.1
    10/20/2009 10:18:43 PM: Que Exec: True, menu.skin, "load;radio_player.skin||RTune;106.1", False
    10/20/2009 10:18:43 PM: Executing: load;radio_player.skin
    10/20/2009 10:18:43 PM: Que Exec: True, radio_player.skin, "ONSCREENCHANGE", False
    10/20/2009 10:18:43 PM: Que Exec: True, radio_player.skin, "RTune;106.1", False
    10/20/2009 10:18:43 PM: Leave Exec: False, radio_player.skin, RTune;106.1, False
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I assume JohnWPB is using the lastest as he is the one who brought it to my attention.
    John can you confirm which version you are using?
    Mitch, it doesn't load the screen
    it comes up with the following (courtesy of John again)
    It does handle some double commands just not this one sent after I hijack an onclick event.
    And as I said in the first post, works fine in RoadRunner.
    MySQL Error
    Oct 2004
    Ok, i see the issue
    "Onxxx" events where NEVER intended or allowed to be overridden inside a plugin
    we added code (while back) that EVERY plugin would see the ONevent so that it can REACT to it...
    proper coding intended to be
    you catch the ONxxxx Event, and do Execute("load;trafficcam_search.skin||rrtc_onclcli ck")
    by doing a reference replace in the plugin like you did, actually causes other plugins NOT to see the ONxxx event
    which is NOT what we want...
    I am adding some code to assure all plugins see the ONxxx event, and still allow u to do a processcommand=3 override
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    Ok, i see the issue
    Well I don't just randomly replace it. I check that it is in a specific form before hijacking it.
    There should be no other plugins that need to know the onclclick event if it is in one of my plugins form/screen/.skin whatever you want to call it.
    However I will change that to an execute and see how it goes.
    Edit. Ok that works in RoadRunner, I'll try it in RideRunner later
    MySQL Error
    Oct 2004
    Ok,
    the new code is added, you can "hijack" the ONevents, it will queue up your new command
    AND it will NOT destroy the ONEvent for the next plugin
    so... you dont have to change your code if you dont really want to
    the whole idea was that ANY ONEvent say "ONSUSPEND" should be seen by ALL plugins, and even if u did an Exectbl translation, EVERY plugin would see the "ONSUSPEND"
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I already have for the new versions.
    it worked in RideRunner as well. So I will leave it as an sdk.execute (hmm, or will I?)
    <goes to check out new exe>
  1. music defaults to first song on open
    By soundman98 in forum Road Runner
    Last Post: 11-23-2009, 03:36 AM
  2. Replies: 13
    Last Post: 05-28-2009, 04:18 PM
  3. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  4. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
