Results 1 to 10 of 11
Thread: SetLabel
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    SetLabel
    Is it me or is the command SetLabel not working anymore? I have a command where I call a MENU but the label is not populating. Here is my command.
    "ESC||RM_Add2Disk1||MENU;AddSong.skin||SETLABEL;!D iskNumber;1"
    Now, AddSong pops up but the label is blank.
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    NOT working for me either... Using the skin tool I cant get it to work even using the exact syntax from the Skin Commands.txt
    I think this bug can be considered CONFIRMED...
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    OH yeah, I using the October release of RR...
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    November update neither. Need to be looked at by the Gurus.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just tested this here (and works):
    L,625,25,117,25,28,68,227,18,"Arial:B","!test",""
    with command:
    setlabel;!test;Hello!
    can any of you post a .skin and command combination which isn't working ?
    Ride Runner RR's Myspace
    Aug 2006
    West Allis, WI
    Im testing using the skintool
    command
    label code
    !test
    Aug 2006
    West Allis, WI
    Ok works if I put the label in a skin and put the ! before the label code.
    If there is no ! then the label displays then goes blank.
    Still can't get the skin tool to get the label information though.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by guino View Post
    with command:
    Why use a test label that starts w/ a "!"?? Was there something new that the "!" in front of a std lbl changes or does?
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    MySQL Error
    Oct 2004
    yes... the ! does do something
    it sounds obsoleted
    and one should use a label and a var
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    guino's Avatar
    Nov 2004
    Toronto, Canada
    ! in front of a label is the same as "CUSTOM" in front of a label. This IS AN OBSOLETE feature and only works in the SKIN itself as setlabel will directly set the label text without ever setting/reading it again -- this means that skintool (or any other plugin) will never be able to read it.
    As mentioned, this feature is obsolete and is only available to support older plugins/applications still using it. The RECOMMENDED way of doing exactly the same is:
    LABEL CODE: Instead of "!TEST" use "=$TEST$"
    COMMAND: Instead of "SETLABEL;!TEST;Hello!" use "SETVAR;TEST;Hello!"
    The results are the same, however you CAN read the variable from skintool/plugins and furthermore, the command will work for displaying the data on ALL screens of RR without having to resend it for every screen (using SETLABEL you'd only set that label on the CURRENT screen and if you wanted to show the data on different screens, you'd have to execute SETLABEL again after every screen change - or on a timed basis).
  1. MENU POPUP with - SetVar / SetLabel question ...
    By kolemieux in forum Road Runner
    Last Post: 07-19-2007, 03:35 AM
  2. SETLABEL and greek chars?
    By gaslan in forum Road Runner
    Last Post: 03-19-2007, 07:14 PM
  3. setlabel?
    By Chuck in forum Road Runner
    Last Post: 03-20-2006, 12:19 AM
