Results 11 to 20 of 25
Thread: RR, Silabs and TP?
  1. #11
    Aug 2009
    UK
    But the silabs tuner seems to have the RDS features so with a second tuner could we get it to work?
    The way I see it working is where the tuner that isn't in use is scanning for TA flags and then RR switches to that tuner when it finds one ie when a traffic announcement comes on.
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I believe the guys working on the silabs DLL had even looked into using dual tuners for that purpose, but I do not know how far they got with it. You may want to search around the net for that.
    Ride Runner RR's Myspace
  3. #13
    MySQL Error
    Oct 2004
    wolvers, you could try that now, have a station tuned that has Traffic Announcements...
    and put in the exectbl.ini code to do something with the event
    "ONTASTART","RADIO"
    would be at its simplest
    then if a TA comes in, it should switch to radio
    i cant be 100%, cause i cant test TA, since no radio stations in my area use them
    part of the problem, is its NOT used in most of the USA, if not all
    anymore
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    Aug 2009
    UK
    Thanks mitch, I'll give it a try. I take it I need to have the RDS_TA function on for it to work? I have got a button available for that.
    At least then I could leave it tuned to the station that I want to get the TA from and listen to some tunes from my library, then hopefully it would switch to it when the TA comes on.
  5. #15
    MySQL Error
    Oct 2004
    yes. it has to be "ON" to allow that event to happen
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #16
    Aug 2009
    UK
    Tried this this morning with some, but not complete, success. It didn't switch to the radio but I checked with skintool and I did get a couple of ONTASTART (and then ONTAEND) events.
    Could I of entered the "ONTASTART","RADIO" line into exectbl.ini incorrectly? I just put it after the other similar looking commands.
    I was wondering if it should be something like "ONTASTART","RADIO_ON"? I need to have a look through all of the skin commands I suppose.
    Thanks for all your help.
  7. #17
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You may want to check that there's not already a "ONTASTART" before (on top of) the one you put in -- that would take priority over the one you added below.
  8. #18
    Aug 2009
    UK
    Thanks for your reply. I've checked that and there isn't another one.
    I think I'll try a LOAD:radio_player.skin command and see what happens?
    Edit; I just noticed in the RRSkin Tool log file that it's come up as ONRDSTASTART so I'll try that. It says that in the radioplayer commands doc as well so I'm obviously a muppet for just copying what Mitch wrote!
  9. #19
    MySQL Error
    Oct 2004
    heheh
    sorry
    you know i did document it, read the history.txt and new radio commands.txt documents
    but i cant remember it
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #20
    Aug 2009
    UK
    Ah, no problem. It's all part of my RR learning curve. I've changed it now so I'll test it out in the morning rush hour.
  1. What Radio do you use with RideRunner?
    By mitchjs in forum Road Runner
    Last Post: 07-21-2010, 09:22 AM
  2. Silabs USB Radio
    By JohnnySierra in forum RR Bug Tracker
    Last Post: 05-11-2009, 06:28 AM
  3. 05/27/08 Road Runner Official Beta, Weather Fixed!
    By JohnWPB in forum Road Runner
    Last Post: 09-02-2008, 07:06 AM
