Results 1 to 6 of 6
Thread: Riderunner from save playlist error
    Jun 2007
    I save playlist and load playlist to play it error about font and can not play..
    I test on foobar plugin player
    When I test on winamp player it error too.
    MySQL Error
    Oct 2004
    you might want to read this
    http://www.mp3car.com/vbulletin/rr-f...ml#post1353843
    playlist cannot load/save from a dir with NWU chars (NWU (Non-Western Unicode))
    thats prob, your problem
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jun 2007
    Thank you for answer.
    Jan 2006
    I'm having a problem with RideRunner's playlist. When I click the 'eject' button to show the music directory, I see all the music files there as normal. When I click the top item (the three dots '...') it is supposed to move to the previous directory, but it doesn't. It simply takes me back to RideRunner's music player and starts playing the current music. I've just switched to using Foobar2000 and previously I was using Winamp, this never used to happen when I used Winamp.
    Any idea why? I wanna load different playlists and I need this to work, but it won't let me change my playlist. Even if I run Foobar on its own and load a new playlist into it, and then close it, and run RideRunner, RideRunner still shows the previous playlist and plays from that only.
    Jun 2007
    Now
    about bug saveplaylist is fix by edit skin command .. use .m3u8
    edit save and open playlist it work for Thaisong . I wish other language work too..
    "osktocmd;listname;savelist;$playlistpath$$listnam e$.m3u8",
    "$PLAYLISTPATH$",".m3u.m3u8",0,,,,,,,
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by MeeM View Post
    Unless you have a folder called "..." (THREE dots), RR will not put it there -- RR should only show ".." (TWO dots) to go back to a previous folder -- when you don't the use hide dots option. You should make a debug log to see if the skin you're using (which you haven't mentioned) is overriding the default double click action. I can also suggest you try a different skin to see if double clicking the ".." (TWO dots) takes you back one folder.
    RR doesn't use or mess with the Foobar playlist - it creates a separate playlist to work with, then removes it before exiting - messing with the playlist in foobar will do no good.
    NOTE: that if you're trying to double click the ".." in the default MUSIC folder or default VIDEO folder -- the default action is to load all your songs! You can only back out of the default MUSIC/VIDEO folder if you set pathlimit=false in RR.INI (probably option in RRConfig as well).
    Ride Runner RR's Myspace
  1. Fusion Brain program for Linux
    By malcom2073 in forum Fusion Brain
    Last Post: 08-30-2010, 01:25 PM
  2. Virtual Earth cache builder? Or even gps simulator to make it cache?
    By thepunkerguy in forum DigitalMods (Scripts / API)
    Last Post: 08-28-2008, 09:58 PM
  3. Playlist Strangeness
    By nasa in forum Road Runner
    Last Post: 08-17-2008, 10:05 AM
  4. how can you save a playlist?
    By brandensin in forum Road Runner
    Last Post: 07-30-2008, 12:15 AM
  5. Playlist and save bugs
    By tolisn in forum RR Bug Tracker
    Last Post: 04-05-2005, 12:16 AM
