Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Video problems
  1. #11
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    I just tried out the new version
    The same problem still exists when the video file names are in Greek
  2. #12
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by tolisn
    What problem are you referring to ? displaying the characters or being able to open the files with wird characters ?
    The files won't open (yet) because MPC doesn't support foreign charsets on playlists.. it won't load them nor save them.. that's why I'm thinking of writing simple video player to use with RR. It woudn't have as many features as MPC but it would definitely support those foreign characters...
    See images from my machine right now:
    Ride Runner RR's Myspace
  3. #13
    Dec 2003
    Greece
    [QUOTE=guino]What problem are you referring to ? displaying the characters or being able to open the files with wird characters ?
    Well Guino, the problem is as follows:
    1. The file does not load if it has Greek characters in the files name.
    2. If the file name contains Greek characters it shows up OK.
    3. If I run MPC as a standalone program (without RR) and select the file containing Greek characters then it plays OK (This same file does not play from within RR).
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yeah.. I know about that .. try this: open MPC (outside RR) and click View->Playlist. Now drag a few files to your playlist (with greek chars) then right click on the playlist's bar and select "save...". Save it as a m3u file (the simplest one). Close MPC and re-open it. Click to open plailist (or file/open) and select the playlist you made.. you will see that MPC will not open the files.. if you look at your playlist file you'll see that all greek characters have been removed from it..
    What is going on is that RR is working fine, but MPC is screwing up.. that's why I have decided to add a built-in video player to RR. so that this is not going to happen anymore and so that MPC is an option.
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Tolisn, please try the built in video player for your "greek" named files.. I've tested it here and it seems to work well (unlike MPC). Just make sure you don't disable Internationalization and use the Built In Player.. also you should either use "System" or "Greek" for the locale setting in RR.
    http://rmc.pimpedwheels.com/RoadRunnerBinary.zip
  1. DVD playing causes video problems
    By roleary in forum General Hardware Discussion
    Last Post: 12-06-2004, 10:11 AM
  2. Video car problems....
    By joelw23 in forum General Hardware Discussion
    Last Post: 11-03-2004, 11:28 AM
  3. Weird problems with video and ME 2.1
    By Rireal in forum Media Engine
    Last Post: 02-20-2004, 06:33 PM
  4. FV24 and DC10+ video caputure board problems
    By komarak in forum General Hardware Discussion
    Last Post: 01-29-2004, 06:32 PM
  5. sv24 video problems again
    By Holden__V8 in forum General Hardware Discussion
    Last Post: 01-06-2003, 09:00 AM
