Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 61
Thread: Bug Thread?
  1. #21
    Constant Bitrate vortex's Avatar
    Feb 2005
    London, UK
    Quote Originally Posted by guino
    Are you using any kind of re-scaling ? (i.e. 800x480 for the 800x600 skin) ? I am pretty sure I have added support for re-scaling the Touch-Wheel, so it should work.. I'd double check you have the audio_player.skin file setup correctly. I'll double check on it..
    It's working fine on the latest version i started with a fresh install.
  2. #22
    FLAC mauri's Avatar
    Jan 2004
    problem with the DVD & DIVX player.
    Use one small file .mpeg for test.
    The old version palyed this file ok,the new 02/05 version don't palyed.
    Winamp problem.
    Two debug :
    debug_winamp_mediacar and setting path to conf. utility winamp embedded to Mediacar,and debug_winamp its in the winamp directory.
    Mauri
    Attached Files Attached Files
  3. #23
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by mauri
    Winamp problem.
    Two debug :
    Mauri
    You're saying the Video player is not opening right ? Do you get any "external" error message ? or just don't get the 321 (MPC) screen ? I recommend checking your settings after every update.. If winamp is opening on the video/dvd player, the problem is actually with the Media Player Path and not with the Winamp path (so shoudn't matter which winamp you use)
    I'm adding more debug info the version I'll post later today..
  4. #24
    Constant Bitrate Phythorian's Avatar
    Dec 2004
    Netherlands
    I'm having a dvd playback problem,
    when I play a dvd, the videoscreen splits in two an the right half is shown left and left shows on the right side. Like the offset of the screen starts in the middle, and what's not shown appears on the other side.
    When I use windvd directly, it works fine, no problems.
    Any idea?
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Phythorian
    Any idea?
    oh boy... never seen that before.. try Media Player Classic directly (without RR running) then right click and say Open DVD... see if it plays right, if so, it's a RR bug, if it has the same problem, it's a Bug of Media Player Classic -- you can probably try changing its settings to see if it works.
  6. #26
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Update with the news, fixed all problem, but one chose really strange:
    with the preview version of RR (with bug), I have used for closing Winamp crashed the " Task Manager " and now me and disappeared the superior bar of this.
    See the screenshot.
    Mauri
    Dude, this is a task manager "feature", just double click on the border and it will show the menu again...
  7. #27
    FLAC mauri's Avatar
    Jan 2004
    Today I am really dormant
    Mauri
  8. #28
    Dec 2004
    Netherlands
    Hey Guino,
    MPC runs the dvd playback just fine without the "split-screen" when not embedded in RR, I still have the 06-02 version running, going to install your new one today.
    Other thing is when I playback dvd in RR the taskmanager shows almost 95% CPU activity, when I play the same dvdscene in MPC it doesn't come higher as 60%. In RR the playback isn't smooth anymore but hackles a bit.
    I have the via-epia M10000 mobo and DVD throuh USB2.0.
    I'll try if it's better with your new version and let you know.
  9. #29
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Hey Guino,
    Did you try messing with MPC's settings (acceleration etc) ? I'll check on it and try to see what I can do about the performance...
  10. #30
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Hi i just installed everything on a new computer running windows 2000 pro, and i get "runtime error '9' subscript out of range" the log tells me 2/8/2005 12:58:06 PM: Start
    2/8/2005 12:58:06 PM: Winamp window not found.
    2/8/2005 12:58:06 PM: Shell: "c:\program files\winamp\winamp.exe"
    2/8/2005 12:58:07 PM: Shell: "C:\Program Files\MediaCar\gamma\gammacontrol.exe"
  1. Bug Tracking List
    By d_sellers1 in forum MMC Bug Tracking
    Last Post: 04-01-2007, 11:02 PM
  2. Replies: 27
    Last Post: 12-20-2005, 09:29 AM
  3. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  4. skins thread suggestion
    By liquid_smoke in forum FrodoPlayer
    Last Post: 11-11-2004, 10:31 PM
  5. Replies: 3
    Last Post: 01-07-2004, 12:52 PM
