Sounds Good......
One more thing....
I think this one was addressed before, but ....is there any way to make the video autoresume?? I don't know how many more times I can watch the opening to the Matrix....![]()
Thanks again for all the effort
Easy to add.. but then, you'll have to add a button in the skin to do that.. :/ I'll put in the command so that someone might add it in the skin..Originally Posted by Dark_Falcon
Sounds Good......
One more thing....
The new version will somewhat "resume" to your last used playlist.. so if you make a new playlist that doesn't star with "matrix" you should see other stuff when going in the video screen.. I have a function to "seek" in the video screen but it needs to be well tweaked before making it available.. :/Originally Posted by Dark_Falcon
btw... can u make a playlist of videos? i didnt see the button for that... thanks..
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
what exactly you mean ? I have to re-structure the functions of the video browser anyway.. I don't even remember what they do right now..Originally Posted by Chita79
nm.... :P its all good
I was hoping for it to pick up at the same spot prior to shutdown (similar to the music playing). However, a seek function would work just as well.Originally Posted by guino
While your at it, is there any way to have a seek function on the Audio as well. I listen to a lot of audio books and each track can be 30-40 minutes a piece. It would be nice if I could move to a particular spot in a single track. These are obviously wish items. The app is awesome and much appreciated.
Get the latest BrushMetalUpdate.. it has a blinking mute button and a Seekbar.. no credits to myself (thank the skinners).. there's a commented line for the "Shuffle" indicator, that you might want to uncomment (until I release a new update), so you can see the shuffle indicator -- it works.Originally Posted by Dark_Falcon
don't think anyone is having this prob...when i go into the audio player (id tags set) and have the skin set to show the artist/album too, the only one that shows is the song name. but if i select another song the info shows up..then if you completely exit RR and start it again the art/alb info is missing again. any idea's thanks..
maybe taged wrong..or something.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
When I was adding ID3 support I thought there was a bunch of bugs.. but infact I had a bunch of Tags with missing info (album specially), so when loading the tags it is important to set the ID3 info correctly.. If you use ID3v2 as preferred, you might run in cases when the MP3 file has ID3 info but has not Title/Artis/Album info -- this happens when some stupid programs add custom tags into the ID3 without setting the rest of the ID3 info. I might try to find a way to pull up the "bits and pieces" of the tags together when they're missing so that if you have the title only in the ID3v1 and the Album only on the ID3v2 they would still load up correctly.. right now, it uses the first tag it finds only.Originally Posted by Blue ZX3
