Results 1 to 10 of 15
Thread: master volume doesnīt work
    i canīt change the master volume in any skin .
    anytime i press on on button for mastervolume it will be set to "0"
    and i canīt move the slider for this.
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    So you have the Via M10000?
    no i test RR on my normal computer (board from gigabyte )
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by free2world8000
    does it show the correct master volume level when you first go in RR ? Typically, the volume show show and stay at Zero only when your soundcard does not support that source type (i.e. bass, treble etc)
    i think thatīs my problem what can i do?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You did not answer my question:
    does it show the correct master volume level when you first go in RR ? Or does it show Zero (even though you have it set to something else) ?
    I need to know this in order to think of an answer... Are you able to set the volume with Windows Mixer?
    no
    yes
    yes i can set my volume with windows mixer
    guino's Avatar
    Nov 2004
    Toronto, Canada
    no
    yes
    Ok, try the new version, probably still won't work but what I need from you is to add the following line into RR.INI:
    debugmode=true
    then Run RR, try setting the volume and then exit...
    Send me the debug.txt file created by email or PM..
    Thanks.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This issue has been resolved by adding the feature to map the master volume into a specific sound card line ...
    Ride Runner RR's Myspace
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    I still have the volumn issue.
    For example current Master volumn is set to 15% (using Windows volumn/eq thinggy).
    Load up RR, volumn show 0, but music sound is coming out fine and loundness is at 15% as suppose.
    Click on either VOL UP or DOWN, the volumn is set back to 0. If I keep click VOL UP, the volumn is slowly going up. Currently it map to master volumn.
    [edit]
    BTW this is the latest install/release (2/15)
    [/edit]
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  1. FM Radio- VOlume controls- Mute line-in- control master
    By live2themaxuk in forum FrodoPlayer
    Last Post: 11-16-2004, 03:33 AM
  2. Volume control question..
    By Kamakazie2 in forum Software & Software Development
    Last Post: 10-07-2004, 07:16 PM
  3. Adjusting Volume Level According to Master Volume
    By Xtreme2k2 in forum Software & Software Development
    Last Post: 10-02-2004, 12:51 PM
  4. is it possible to change the volume increment amount?
    By fasternfaster in forum MediaCar
    Last Post: 08-28-2004, 11:30 PM
  5. Sound Volume Issues
    By ether in forum Media Engine
    Last Post: 08-02-2004, 01:24 PM
