Results 1 to 7 of 7
Thread: Two things with RR 2-19-05
    Mar 2004
    Stockholm, Sweden
    1: First change from day gamma to night is OK, but the next change and all after that the night screen turns reddish... Also when you select Built in Gamma the GammaControl.exe still loads, even if i clear the line gammapath= in RR.ini, i have to remove/rename the gamma folder to get rid of gammacontrol.exe...
    2: MapMonkey, first start is OK, but if you close MapMonkey and try to load it again i just get an empty skin... Then if you exit RR and start it again it is working again.
    Same problem on two different computers, with several skins including teh BrushMetal skin with lates update
    Other than that it is working great!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Passe
    I'll look at this.. I think I know what's going on with the gamma, and after released it I noticed the "redish" problem..
    How are you exiting from MM ? X button, Exit Menu or the "back" button ?
    Let me know, I had just fixed a few issues with that earlier today (before release)..
    Ride Runner RR's Myspace
    Mar 2004
    Stockholm, Sweden
    I exit with X, back button works ok, but then MM is still running, X is closing MM, and it does, because it is gone from task manager. The problem is when RR should relaunch MM.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    On my tests, that was working fine.. anyway, if you don't close MM, it won't interfere with your activities unless you want to run another GPS app. If you exit RR while MM is running on the background, RR will close MM for you (now it will).
    Mar 2004
    Stockholm, Sweden
    Quote Originally Posted by guino
    Problem is, i need to be able to switch between two GPS apps...
    Tried it on a third computer clean install, still the same, and also if you close MM from itself you get the same result. Replaced RR.exe with 2-15 version, it is working perfectly.
    This is what i get from debug in old version 2-15:
    2005-02-19 12:23:52: Executing: GPS
    2005-02-19 12:23:53: Shell: "C:\DestinatorApps\Map Monkey\MapMonkey.exe"
    2005-02-19 12:24:05: Executing: CLOSE
    2005-02-19 12:24:09: Executing: GPS
    2005-02-19 12:24:09: Shell: "C:\DestinatorApps\Map Monkey\MapMonkey.exe"
    2005-02-19 12:24:15: Executing: CLOSE
    2005-02-19 12:24:17: Executing: EXIT
    This i what i get from new version 2-19 when doing the same thing:
    2005-02-19 12:27:42: Executing: GPS
    2005-02-19 12:27:44: Shell: "C:\DestinatorApps\Map Monkey\MapMonkey.exe"
    2005-02-19 12:27:49: Executing: CLOSE
    2005-02-19 12:27:52: Executing: GPS
    2005-02-19 12:27:57: Executing: CLOSE
    2005-02-19 12:27:59: Executing: EXIT
    The only thing that i changed between these two tests is replacing RR.exe.
    Any idea what is going on???
    Mar 2004
    Stockholm, Sweden
    Update:
    Tried to set up MM as external gps, and this is working...
    It is closing and reopening fine...
    Problem is, i need another GPS app as external...
    Hope you can help me on this one Guino...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Update:
    Don't worry, I'll fix it..
    EDIT: Fixed (hopefully).
  1. RR Holistic v2.2 Beta skin is ready for download
    By holistic in forum RR Skins
    Last Post: 02-05-2007, 09:21 AM
  2. Wild Things PSone LCD to PC
    By godzi11a in forum LCD/Display
    Last Post: 11-22-2005, 07:13 PM
  3. RR 2-19-05 .. little things..
    By guino in forum Road Runner
    Last Post: 02-20-2005, 12:55 AM
  4. Rage against some stupid things
    By kraft in forum Off Topic
    Last Post: 11-07-2004, 04:29 PM
  5. Control things and display status of things
    By All4Norway in forum General Hardware Discussion
    Last Post: 07-18-2002, 01:32 PM
